Topic: Will the bootloader be erased if hex code is uploaded using programmer? (Read 986 times) previous topic - next topic
lightaiyee
I am going to buy a programmer and test it out. Will the bootloader be erased if hex code is uploaded using programmer? If I want to use back the Arduino IDE, do I have to re-upload the Arduino bootloader back?
Runaway Pancake
Right.
If an Arduino ("chip", et al.) is uploaded via ICSP then the bootloader gets wiped out.
To then upload to the Arduino via USB/serial will require its being re-bootloaded.
You can upload via ICSP from within the Arduino IDE, too.
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
fungus
[/quote]
Yes.
Yes.
Papa G
Just make sure the last hex code file you program is a bootloader.  :)
