Topic: Rogue tone library, mega 2560 r3 and millis() simple problem (Read 2336 times) previous topic - next topic
baelthazoar
I'm finally managing to isolate what has been messing with me with a project and it's been driving me nuts chasing it.
Anyway, using the tone library and enabling any more than two tones (on a Mega 2560 with 6 timers), causes it to not work. I've looked at the cpp, read up on timer pins and conflicts and have tried a load of variations, but it comes down to this:
Put an indicator LED in pin 40 with the - leg tied to ground thru a 1k resistor, and toggle on
Tone tone3;
Tone tone4;
Presto! no longer works.
Anybody have any ideas?
Code: [Select]
#include <Tone.h>
int blinker = 40;
unsigned long lastTime;
int blinkerState = LOW;
int wait = 200;
Tone tone1;
Tone tone2;
//Tone tone3;
//Tone tone4;
  pinMode(blinker, OUTPUT);
  tone1.begin(7);
  tone2.begin(6);
//  tone3.begin(5);
//  tone4.begin(4);
//__________________________________________________________LOOP
  unsigned long currentMillis=millis();
  if ((currentMillis - lastTime) >=  wait)
    lastTime=currentMillis;
      if (blinkerState == LOW)
        blinkerState = HIGH;
        blinkerState = LOW;
      digitalWrite(blinker, blinkerState);
Coding Badly
baelthazoar
https://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
here it is, I think the problem may be in the .cpp, and not identifying the mega 2560,
changing this:
#if defined(__AVR_ATmega1280__)
to this:
#if defined(__AVR_ATmega1280__)||(__AVR_ATmega2560__)
might have fixed it, I'll test it this afternoon.
Coding Badly
baelthazoar
I believe that did the trick, I'll be able to tell more once I get further along with the envelopes and the hardware.
I also took out all the library inclusions in the .cpp, this seems to work:
#include <arduino.h>
#include "Tone.h"
