Topic: I want to make a video play when someone walks past (Read 5365 times) previous topic - next topic
Mossi
Apr 06, 2013, 08:39 pm Last Edit: Apr 08, 2013, 03:51 pm by Mossi Reason: 1
Hello,
I'm rather new to this. I'm doing an art installation and using an IR sensor I want to make a video play once the person has walked past it. They will be roughly 50cm away before it should play.
I have started code with help from a friend and when I hit run the numbers get bigger when I move my hand closer and the video sound is heard (I would like to see the picture too) at the beginning once i've first pressed run but once it has finishes when I put my hand back there the video doesn't replay. Here is the code -
Code: [Select]
* Serial Call-Response
* by Tom Igoe.
* Sends a byte out the serial port, and reads 3 bytes in.
* Sets foregound color, xpos, and ypos of a circle onstage
* using the values returned from the serial port.
* Thanks to Daniel Shiffman  and Greg Shakar for the improvements.
* Note: This sketch assumes that the device on the other end of the serial
* port is going to send a single byte of value 65 (ASCII A) on startup.
* The sketch waits for that byte, then sends an ASCII A whenever
* it wants more data.
import processing.video.*;
Movie myMovie;
import processing.serial.*;
int bgcolor;      // Background color
int fgcolor;      // Fill color
Serial myPort;                       // The serial port
int[] serialInArray = new int[3];    // Where we'll put what we receive
int serialCount = 0;                 // A count of how many bytes we receive
int xpos, ypos;              // Starting position of the ball
boolean firstContact = false;        // Whether we've heard from the microcontroller
 size(256, 256);  // Stage size
 noStroke();      // No border on the next thing drawn
 myMovie = new Movie(this, "MajorProjectVid.mov");
 // Set the starting position of the ball (middle of the stage)
 xpos = width/2;
 ypos = height/2;
 // Print a list of the serial ports, for debugging purposes:
 println(Serial.list());
 // I know that the first port in the serial list on my mac
 // is always my  FTDI adaptor, so I open Serial.list()[0].
 // On Windows machines, this generally opens COM1.
 // Open whatever port is the one you're using.
 String portName = Serial.list()[0];
 myPort = new Serial(this, portName, 9600);
void movieEvent(Movie myMovie) {
 myMovie.read();
void draw() {
 //background(255);
 //fill(fgcolor);
 // Draw the shape
 //ellipse(xpos, height/2, 20, 20);
 if(xpos > 190){
   image(myMovie,0,0,width, height);
 }else background(0);
void serialEvent(Serial myPort) {
 // read a byte from the serial port:
 int inByte = myPort.read();
 // if this is the first byte received, and it's an A,
 // clear the serial buffer and note that you've
 // had first contact from the microcontroller.
 // Otherwise, add the incoming byte to the array:
 if (firstContact == false) {
   if (inByte == 'A') {
     myPort.clear();          // clear the serial port buffer
     firstContact = true;     // you've had first contact from the microcontroller
     myPort.write('A');       // ask for more
 else {
   // Add the latest byte from the serial port to array:
   serialInArray[serialCount] = inByte;
   serialCount++;
   // If we have 3 bytes:
   if (serialCount > 2 ) {
     xpos = serialInArray[0];
     ypos = serialInArray[1];
     fgcolor = serialInArray[2];
     // print the values (for debugging purposes only):
     println(xpos + "\t" + ypos + "\t" + fgcolor);
     // Send a capital A to request new sensor readings:
     myPort.write('A');
     // Reset serialCount:
     serialCount = 0;
//  Serial Call and Response
//  by Tom Igoe
//  Language: Wiring/Arduino
//  This program sends an ASCII A (byte of value 65) on startup
//  and repeats that until it gets some data in.
//  Then it waits for a byte in the serial port, and
//  sends three sensor values whenever it gets a byte in.
//  Thanks to Greg Shakar for the improvements
//  Created 26 Sept. 2005
//  Updated 18 April 2008
int firstSensor = 0;    // first analog sensor
int secondSensor = 0;   // second analog sensor
int thirdSensor = 0;    // digital sensor
int inByte = 0;         // incoming serial byte
 // start serial port at 9600 bps:
 pinMode(2, INPUT);   // digital sensor is on digital pin 2
 establishContact();  // send a byte to establish contact until Processing responds
 // if we get a valid byte, read analog ins:
 if (Serial.available() > 0) {
   // get incoming byte:
   inByte = Serial.read();
   // read first analog input, divide by 4 to make the range 0-255:
   firstSensor = analogRead(0)/4;
   // delay 10ms to let the ADC recover:
   delay(10);
   // read second analog input, divide by 4 to make the range 0-255:
   secondSensor = analogRead(1)/4;
   // read  switch, multiply by 155 and add 100
   // so that you're sending 100 or 255:
   thirdSensor = 100 + (155 * digitalRead(2));
   // send sensor values:
   Serial.print(firstSensor, BYTE);
   Serial.print(secondSensor, BYTE);
   Serial.print(thirdSensor, BYTE);
void establishContact() {
while (Serial.available() <= 0) {
     Serial.print('A', BYTE);   // send a capital A
     delay(300);
Grumpy_Mike
Read the how to use this forum sticky post. Then modify that post so the code is in the correct format with code tags.
Mossi
Done :)
I have since found a new plug in called GSMovie which seems to allow you to see the video. The numbers are still at the bottom but again it is not playing the video when I hover my hand over...
Code: [Select]
* by Tom Igoe.
import codeanticode.gsvideo.*;
GSMovie movie;
  size(640, 480);  // Stage size
   movie = new GSMovie(this, "MajorProjectVid.mov");
  movie.loop();
  xpos = width/2;
  ypos = height/2;
void movieEvent(GSMovie movie) {
  movie.read();
void draw() {
  //background(255);
  //fill(fgcolor);
  // Draw the shape
  if(xpos > 190){
    image(movie,0,0,width, height);
  else {
    serialCount++;
      myPort.write('A');
      serialCount = 0;
//  by Tom Igoe
    delay(10);
      delay(300);
Grumpy_Mike
Thanks for making the changes.
You need to test each end to see where it is going wrong.
So first off just make a sketch that sends a single character to your processing sketch and see if that works.
Then connect the serial monitor to the arduino and test that your hand waving sends the required character.
Mossi
Ok, I apologise I am really quite new to this and someone helped me set up the initial code (not entirely sure how they did it, I know they mixed Arduino and Processing). In order to do what your suggesting do I use an example from Arduino and one from Processing if so which one? Sorry again.
Mossi
SerialCallResponse works on processing just trying to figure out arduino...
Grumpy_Mike
It looks like it is very old arduino code. This bit:-
Code: [Select]
should be
Code: [Select]
    Serial.write(byte(firstSensor));
    Serial.write(byte(secondSensor));
    Serial.write(byte(thirdSensor));
Mossi
I changed that code thanks, still seems to just play on repeat. Don't know if this has something to do with it but when the numbers at the bottom are scrolling they don't start at 0 when my hand is away and go higher when I move my hand, it's constantly around 255
Grumpy_Mike
Quote
Are you are using code that you have not posted?
Quote
Sorry I don't know what that means.
Mossi
Still using the same code sorry I meant when I move my hand closer to the IR Sensor, the numbers at the bottom of the code stay around 250, suggesting it can't tell if the code should be true or false as my guess (this might be the problem?). The video plays on repeat on a loop rather than only re-playing when my hand is near (as if the person were walking past)
Grumpy_Mike
Quote
That is because:-
Quote
As I said before you should check the arduino part of the code. Why are you sending three bytes when you only need one?
It looks like your sensor is not working like you think it should. Have you tested this with a sketch that just prints out the sensor value?
You have to get that bit working before trying to do the more complex thing of triggering a video.
Mossi
Quote
I think this is because in the processing example (Serial CallResponse) which is used in this code there are 3 (the IR Sensor has 3 wires - red, white and black maybe this is why you need three?).
Yesterday I used the Serial CallResponse using Processing version 1.5.1 and it worked. Today I tried the same example on Arduino and it worked (the numbers started around 30 and went up as my hand got closer). I then went back to the Processing Serial CallResponse and now it doesn't work (there is just a black screen when I click run).
Grumpy_Mike
Quote
Yes my point is why have you left it in when it is not needed?
I have been thinking about your problem and the Processing code is a bit odd. It will only change the value of the xpos variable when a byte is received. Therefore if the arduino never sends anything else the movie will keep on playing. What is more, if the call to play the movie is returns before the movie finishes then the requests will just stack up and it will look like the movie is just looping. After the if statement and the call to play the movie you should reset xpos to zero to make sure you don't repeatedly keep on triggering it.
Mossi
Do you mean change this -
Code: [Select]
To this? -
Code: [Select]
    if (serialCount > 1 ) {
Mossi
I think one of the problems may be that processing isn't registering arduino but not sure how to fix that
