Topic: adressing data from assembler (Read 3068 times) previous topic - next topic
rompelstilchen
Hello,
[sorry , i could not post this in "Syntax..." on the forum, donno why...]
i am optimizing my code with inline assembler but i got questions...
ex: i have to acess elements of a 2 dimentional array one by one and refer them as operands that gonna be mapped to registers
__asm__ __volatile__
    "mov r24,%[LEDS]" "\n\t"
: [LEDS] "+r" (leds[0][0].value) ::
how do i adress a whole array instead of having to assign 1 register per operand ?
the problem is that if i use too many operands, the compiler generates a lot of code to load data in registers (before my code)
and a lot of code to load modified registers back to the memory (after my code)
so i thought i could do the adressing myself by storing the adress of an array for instance in the z register
and the parsing memory, read/write the required values, but how to do that ?
also the compiler generates a lot of push before my actual asm code (without any pops ??? wtf?)
does anybody knows why and how to supress this, i lose a lot of cycles for nothing as the whole code runs in the "void loop(){...}" section
ex:
     400: 4f 92        push r4
     402: 5f 92        push r5
     404: 6f 92        push r6
     406: 7f 92        push r7
     408: 8f 92        push r8
     40a: 9f 92        push r9
     40c: af 92        push r10
     40e: bf 92        push r11
     410: cf 92        push r12
     412: df 92        push r13
     414: ef 92        push r14
     416: ff 92        push r15
     418: 0f 93        push r16
     41a: 1f 93        push r17
     41c: df 93        push r29
     41e: cf 93        push r28
     420: 0f 92        push r0
     422: cd b7        in r28, 0x3d ; 61
     424: de b7        in r29, 0x3e ; 62
     426: c0 90 04 04 lds r12, 0x0404
     42a: 8c 2c        mov r8, r12
     42c: 99 24        eor r9, r9
     42e: 70 91 05 04 lds r23, 0x0405
     432: 87 2f        mov r24, r23
     434: 90 e0        ldi r25, 0x00 ; 0
     436: f0 90 36 01 lds r15, 0x0136
     43a: 2c 01        movw r4, r24
     43c: 44 0c        add r4, r4
     43e: 55 1c        adc r5, r5
     440: 44 0c        add r4, r4
     442: 55 1c        adc r5, r5
     444: 48 0e        add r4, r24
     446: 59 1e        adc r5, r25
     448: 88 e7        ldi r24, 0x78 ; 120
     44a: 90 e0        ldi r25, 0x00 ; 0
     44c: 9c 01        movw r18, r24
     44e: 82 9e        mul r8, r18
     450: c0 01        movw r24, r0
     452: 83 9e        mul r8, r19
     454: 90 0d        add r25, r0
     456: 92 9e        mul r9, r18
     458: 90 0d        add r25, r0
     45a: 11 24        eor r1, r1
     45c: 48 0e        add r4, r24
     45e: 59 1e        adc r5, r25
     460: f2 01        movw r30, r4
     462: ec 5c        subi r30, 0xCC ; 204
     464: fe 4f        sbci r31, 0xFE ; 254
     466: 43 81        ldd r20, Z+3 ; 0x03
     468: 54 81        ldd r21, Z+4 ; 0x04
     46a: 91 81        ldd r25, Z+1 ; 0x01
     46c: 30 91 06 04 lds r19, 0x0406
     470: 3a 01        movw r6, r20
     472: b9 2e        mov r11, r25
     474: a3 2e        mov r10, r19
     476: 27 2f        mov r18, r23
     478: 26 95        lsr r18
     47a: 26 95        lsr r18
     47c: 26 95        lsr r18
plz help
thx
Coding Badly
Why?
nickgammon
The compiler optimizes your code too. What makes you think you can do a better job, Rumpelstiltskin?
nickgammon
... i could not post this in "Syntax..." on the forum, donno why...
Because that part of the forum is read-only? Just a guess.
rompelstilchen
Why?
to have you ask why
rompelstilchen
i know, but if you dont try.. right?
btw i end up having a code 10 times faster
seeing the code in asm,  also helps you understand things that could be optimized
rompelstilchen
Why?
i need fast refresh, and with c code, the led panel flickers
arduino is not that fast
afremont
Excellent answer.  Looking at the generated code has always helped me to make more efficient programs.  While the optimizations can be incredible, the compiler does not always generate the most efficient code.
I probably know less about AVR assembler than any other assembler in the world, but I'll try to help.  The tail-end registers can be paired ( R26:R27, R28:R29 and R30:R31).  These are treated as 16-bit pointer registers (X, Y and Z) that can point into SRAM.  Maybe setting one of these as a base pointer and using offsets you can accomplish what you want.  Like I said, I have written no AVR assembler in the past, but I've written tons of ARM7, PIC and mainframe assembler along with scads of other micros.
Experience, it's what you get when you were expecting something else.
Generating your own pro/epilogue code: http://ucexperiment.wordpress.com/2013/03/13/improving-the-interrupt-service-routine/
nickgammon
It's fast enough to generate VGA signals which don't flicker:
http://www.gammon.com.au/forum/?id=11608
I suggest you post your C code rather than trying to convert it all to assembler. By all means look at the generated assembler code, that's what I did. And then work out what lines of C code are generating more assembler code than you though.
To do that, find the .elf file from your compile (turn on verbose compiling) and type this at a command window:
avr-objdump -S -z filename.elf
