Topic: Newbie: A/D project guidance (Read 2779 times) previous topic - next topic
Grumpy_Mike
However, the battery can be disconnected manually (there's a big battery disconnect switch).  There's no impending warning or shutoff process.
So you monitor the voltage on the input side. You have a diode feeding a capacitor before it gets into the arduino. Then you can tell when the power goes off you have a second to save the data, which in the terms of a computer is a long time.
It is best done using the internal comparator firing off an interrupt when the power is disconnected.
dc42
#16
Apr 08, 2013, 12:24 am Last Edit: Apr 08, 2013, 12:26 am by dc42 Reason: 1
How do I detect an impending power failure?  That sounds really useful!
That depends on how you will be powering the Arduino.
Right now it's being powered from a 12VDC battery.  However, the battery can be disconnected manually (there's a big battery disconnect switch).  There's no impending warning or shutoff process.
[EDIT: GM got there first, but here goes anyway]
Pass the 12V supply through a diode feeding a large capacitor to ground, and have that feed the voltage regulator that powers the MCU. Put a voltage divider across the capacitor to bring the maximum voltage to below 5V, and feed that to one of the analog inputs. Read that input at regular intervals (every few ms). When the voltage across the capacitor drops below about 10V, assume an impending power failure and write the important data to EEPROM.
Alternatively, feed the output of the voltage divider to the analog comparator, then you can get an interrupt when the voltage is falling.
Unless you have a lot of additional I/O that you haven't mentioned, then any of them will do. The Leonardo and the Uno are inexpensive and easy to use. However, if you are looking for minimum power consumption and you don't need USB connectivity, then you would be better of using a board without the USB-to-serial converter for the final system.
I'm going to guess that the final version will be a custom board, so anything is possible.  No additional IO planned, but that depends - I am using a pricey serial LCD display for the prototype.  If I can go to a  Hitachi HD44780 LCD, I'd need a bunch of IO to drive it , another 4-6 pins for the keypad, and probably one or two LEDs.
The HD44780 text LCD needs 6 pins. A standard 4 x 3 keypad needs 7 pins. Add 7 for the SPI ADCs and that makes 20. Add an analog input for the power fail detection and that makes 21. The atmega328p only has 20 I/O pins if you use an external crystal, however if you use the internal oscillator instead then you have 22.
Another solution for the LCD might be a ST7920-based 128x64 graphic LCD, which needs only 2 pins to drive it.
You might also consider whether a rotary encoder with integral push button might be a suitable input device instead of a keypad. That would only need 3 pins, or you could reduce it to 1 if you use diode multiplexing and shared the pins driving the HD44780.
cptdondo
My keypad is only 1x4, so if I buy the ebay stuff that's 5 pins, but if this ever goes into production I can set it up as a 2x2 keypad and use 4 pins, so the pin count would work.
Boy, now I really have to get my proof-of-concept working!  :)
