Topic: Sketch too big!!! First time this has happened to me. (Read 750 times) previous topic - next topic
jerseyguy1996
This little block of code:
Code: [Select]
//    if(recording && newReading)
//    if(strcmp(messageID, "GPGGA") == 0)
//        char filename[13];
//        sprintf(filename, "%s.txt", date);
//        if(!SD.exists(filename)) Serial.println("Making Directory");
//        File dataFile = SD.open(filename, FILE_WRITE);
//        // if the file is available, write to it:
//        if (dataFile)
//          dataFile.print(latitude);
//          dataFile.print(",");
//          dataFile.print(longitude);
//          dataFile.println(satsUsed);
//          dataFile.close();
takes my sketch from 27,444 bytes (just under the 28,672 byte limit for the leonardo) to over 33,000 bytes.  Is there a seriously trimmed down version of the SD library or perhaps the adafruit OLED display library that anyone knows about?
Arduino Uno;
Mega328
johnwasser
#1
Apr 07, 2013, 10:48 pm Last Edit: Apr 07, 2013, 10:50 pm by johnwasser Reason: 1
sprintf() is large because it has to incorporate a scripting language.  Try using more primitive operations like strcpy().
Code: [Select]
       char filename[13];
       strcpy(filename, date);
       strcpy(filename + strlen(date), ".txt");
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
jerseyguy1996
I'll give that a try....i use sprintf in a couple of places so maybe I can trim some fat there.
Arduino Uno;
Mega328
