Topic: The frequency slows down continously but takes time to spped up! (Read 5253 times) previous topic - next topic
henrimontreal
Apr 08, 2013, 03:28 am Last Edit: Apr 08, 2013, 04:42 am by henrimontreal Reason: 1
Hi guys,
You helped me to solved some problems of the code but now I got stuck somewhere else!  :smiley-yell:
As you know I had decided to use our buddy, "Serial Monitor" to change the frequency of blinking.
Here is the final code as follows.
Code: [Select]
volatile boolean l;
//unsigned int integerValue=0;  // Max value is 65535
//char incomingByte;
void TC0_Handler()
    long dummy=REG_TC0_SR0; // vital - reading this clears some flag    --- Status REG
                            // otherwise you get infinite interrupts
    l= !l;
    //REG_TC0_CCR0=0b101; //Start counter
//void setFrequen
void setup(){
  Serial.begin(57600);
  pinMode(13,OUTPUT);
void loop(){
       digitalWrite(13,l);
if (Serial.available() > 0) {   // something came across serial
   char buffer[] = {' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL',' NUL'};
Serial.readBytesUntil('\n', buffer, 20);
int  incomingValue = atoi(buffer);
   Serial.println(incomingValue);
   pinMode(2,OUTPUT);    // port B pin 25
  analogWrite(2,255);
   REG_PIOB_PDR = 1<<25; // disable PIO, enable peripheral
  REG_PIOB_ABSR= 1<<25;
     REG_TC0_CMR0=0b00000000000010011100010000000000;
  REG_TC0_IER0=0b00010000;
  REG_TC0_RC0 = incomingValue*1000000;
  NVIC_EnableIRQ(TC0_IRQn);
This works perfectly and each time when I put a new value for "incomingValue", it changes the frequency by changing the amount of "REG_TC0_RC0".
But I can only count up. What does this mean. I mean as follows:
1
8
20
40
80
100
Then I can see the frequency slows down and the LED beats slower and this change is instantly ..... But what if I go this way
1
8
1
Surprisingly it does change it instantly .... from 1 to 8 it is immediately but from 8 to 1 it takes 2 minutes!!!
I look for "COUNT DOWN/UP"  in the datasheet and found the following register:
REG_TC0_SMMR0
which is responsible for count down and up
but I guess the problem is something else...
I am totally confused!
The problem is the "Serial monitor" and the way I used the buffer or NO! The problem is the Register configuration itself?
What do you think?
Any idea about this?
I really appreciate your kind and prompt reply in advance!  :)
el_supremo
Quote
It doesn't even compile.
Pete
Don't send me technical questions via Private Message.
henrimontreal
el_supremo
It still doesn't compile. Why not post the working code?
Pete
henrimontreal
No this works properly. Check out the IDE you work with.
Thanks anyway.
JimboZA
Thanks anyway.
sketch_apr08a.cpp: In function 'void TC0_Handler()':
sketch_apr08a:9: error: 'REG_TC0_SR0' was not declared in this scope
sketch_apr08a.cpp: In function 'void loop()':
sketch_apr08a:42: error: 'REG_PIOB_PDR' was not declared in this scope
sketch_apr08a:43: error: 'REG_PIOB_ABSR' was not declared in this scope
sketch_apr08a:44: error: 'REG_TC0_CMR0' was not declared in this scope
sketch_apr08a:45: error: 'REG_TC0_IER0' was not declared in this scope
sketch_apr08a:47: error: 'REG_TC0_RC0' was not declared in this scope
sketch_apr08a:48: error: 'TC0_IRQn' was not declared in this scope
sketch_apr08a:48: error: 'NVIC_EnableIRQ' was not declared in this scope
To me, that doesn't look like it works perfectly....
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
henrimontreal
This is strange but I use an ARDUINO IDE on mac and it works!
And I have got it from here:
http://arduino.cc/forum/index.php?topic=130423.0
So there must be something wrong on your IDEs.
JimboZA
Quote
Whatever, but I won't be exploring that.
UKHeliBob
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
nickgammon
Doesn't compile for me:
Code: [Select]
sketch_apr08b.ino: In function 'void TC0_Handler()':
sketch_apr08b:9: error: 'REG_TC0_SR0' was not declared in this scope
sketch_apr08b.ino: In function 'void loop()':
sketch_apr08b:42: error: 'REG_PIOB_PDR' was not declared in this scope
sketch_apr08b:43: error: 'REG_PIOB_ABSR' was not declared in this scope
sketch_apr08b:44: error: 'REG_TC0_CMR0' was not declared in this scope
sketch_apr08b:45: error: 'REG_TC0_IER0' was not declared in this scope
sketch_apr08b:47: error: 'REG_TC0_RC0' was not declared in this scope
sketch_apr08b:48: error: 'TC0_IRQn' was not declared in this scope
sketch_apr08b:48: error: 'NVIC_EnableIRQ' was not declared in this scope
It would help to specify what board you have selected, this isn't supposed to be a guessing game.
And please don't use the variable name "l".
Can you see the difference between:
Code: [Select]
foo = 1;  // the number one
foo = l;  // lower-case L
I can't, easily.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
henrimontreal
Quote
Henri, what board and IDE are you using ?
I use Arduino Due and IDE is 1.5.2.
UKHeliBob
It would have been easier if you had said that in the first place.
stimmer
You need to reset the counter whenever you change the period. What can go wrong is, if you shorten the period, the counter might have already gone past the new period value, and then it won't trigger the interrupt until it has counted all the way to 0xFFFFFFFF, wrapped around to 0 and got to the new period value - which is why it takes a while to speed up.
The line REG_TC0_CCR0=0b101; restarts the counter. You need to put it just after REG_TC0_RC0 = incomingValue*1000000;
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
henrimontreal
Stimmer! You are awesome! The problem got solved! Special thank to you!  :)
Now, I have one more question and I wonder if you or anyone who reads this can kindly answer to it. As you can see here and the page 871 and 872 of Datasheet for Arduino Due (AT91SAM), there are some special pins to enable the Timer.
Here we use TC0 Channel 0 and pins 2 1nd 13.
I tried Pin 61 and 62 (For PA2 and PA3 for the AT91SAM ) and TC0 channel 1  to get another independent frequency. For example
instead of REG_TC0_SR0 I have used REG_TC0_SR1. But this approach seems doesn't work properly. Do I need to apply other changes?
Do you know how I can get a couple of unique and completely independent frequency out of this?
Thank you for your help.
