Topic: Mayhew Labs MUX (V1) (Read 574 times) previous topic - next topic
jokboy
Hello Group,
I have a Mayhew Labs MuxShield V1.  I would like to select a number of LEDs in a pattern.  What I thought would work, would be to select an individual pin Reference number, then set that pin to HIGH and cycle to the next one.
The following Code was meant to light pins 8 to 15 sequentially, leaving the previous LED lit when the next one lights up.
Code: [Select]
for (int i=8; i <16; i++)
    digitalWrite(CONTROL0, (i&15)>>3); //S3
    digitalWrite(CONTROL1, (i&7)>>2);  //S2
    digitalWrite(CONTROL2, (i&3)>>1);  //S1
    digitalWrite(CONTROL3, (i&1));     //S0
    digitalWrite(16, HIGH);
    delay(100);
What actually happens is that each individual LED lights up then goes blank when the next one comes on.  What am I doing wrong, or is this a limitation of the MUX Shield?
Regards
Andrew
johnwasser
The analog multiplexers only connect one input/output at a time to your input/output pin.  The rest are disconnected.  This works well for inputs but not well at all for outputs.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
