Topic: LPD8806 want to have pins 2-7 all send same data concurrently (Read 884 times) previous topic - next topic
Augdoc
I am trying to modify the code for the adafruit LED Belt Kit so that an arduino Uno will send the same info for datapin through pins 2-7 and clockpin through pins 8-13 concurrently.  I am trying to attach 7 belt strips (with external power) to run the same sketch concurrently.  Is there any way to do this with the software or will it require a hardware answer (software answer preferred)?
johnwasser
Have you tried connecting more than one belt to the same Clock and Data pins?  In most cases you can output to multiple devices on a single pin.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Augdoc
Yes, it works for 3 strips in each pin but I am trying to wire up 9 strips so I need 3-4 datapins doing the same thing concurrently and 3-4 clockpins as well.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
