Topic: Can the Uno handle two serial port functions ? (Read 13066 times) previous topic - next topic
irethedo
I have an Ardunio Uno that I would like to connect the rxd (d0) and txd (d1) lines
to a serial device to send and receive data with that device.
I also want to echo data to the USB port to a PC to display the data in a Labview application.
Can the Uno handle these two serial port functions with d0/d1 and the USB port?
Thanks
retrolefty
Thanks
No. However you could run a software serial library for the serial device and utilize pins 0 and 1 serial for the PC. The mega board does have four build in hardware serial ports if you wanted to go that way.
Lefty
Jantje
As Lefty stated. Uno no; mega yes.
But the leonardo should be able to do this as well and is cheaper than the mega.
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
irethedo
Thanks for the info...
The Leonardo might work for me if it has 2 serial ports as you say...
Does the Leonardo have the same footprint & pinout as the Uno?
From pictures that I have seen they look the same except for the USB connector
as the Leonardo has a mini, is this correct?
What other differences are there between the Uno and Leonardo?
Nick_Pyner
#4
Apr 09, 2013, 10:30 am Last Edit: Apr 09, 2013, 10:31 am by Nick_Pyner Reason: 1
And it might not as the Leonardo can bring its own limitations to the table, and I understand the software serial library Lefty mentions is written with exactly this in mind, for the Uno you already have, and it is free.
irethedo
Quote
Quote
What limitations?
Nick_Pyner
If I ever knew, I've forgotten. When I looked at the options it was pretty clear that there are essentially two types of Arduino. There is the Uno, Mega, and those of that ilk in the mainstream, and there is the rest in the peripheral niches. On looking at the options, the niches very peripheral and the mainstreamis unsurprisingly where you find the bang for the buck. Most pointedly, you would need to see something pretty convincing to pass up the Uno you already have if that can be persuaded to do what you want at no cost.
irethedo
Does anyone know if the Uno or the Leonardo can be used as a Serial to USB adapter?
pylon
Quote
The Leonardo can be used as this, the UNO includes an ATmega16U2 for this purpose, so theoretically it can be used too. But I guess you question is too general to be of value for your purpose.
irethedo
Quote
Quote
Thanks,
I will scour the web looking for some example code of using the Leonardo as a Serial to USB converter...
irethedo
Does anyone know if a Uno be used as a Serial to USB converter with the use of
the SoftwareSerial library or is this only for Leonardo & Mega arduinos?
thanks
pylon
Quote
You don't need the SoftwareSerial library just for a Serial2USB converter because the UNO has one onboard. Just connect the USB and put the serial device on pins 0 and 1 and you have a USB2Serial device.
Jantje
As you have a uno your best option is to try the software serial. It is just downloading the lib and try.
I have used software serial before and the quality is OK.
One of the differences between UNO and leonardo is that the USB on the UNO is serviced by a chip which is actually connected to pin 0 and 1.
On the Leonardo that is not the case. This means that the serial port on pin 0 and 1 is free for other usages. In other words with the Leonardo you have 2 hardware serial ports.
Leonardo does have some drawbacks as well. Basically it is not as mainstream as the UNO so there were/are libraries that do not support the Leonardo. It changes all the time so if you want a project with the leonardo it is better to check at that time whether all shields/libraries needed support the Leonardo.
Adding this all up: try with your uno and the software serial lib http://arduino.cc/en/Reference/SoftwareSerial.
The comment on the code states
Code: [Select]
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
Sounds like what you are looking for.
Best regards
Jantje
irethedo
Quote
Quote
Thanks for the ideas...
Has anyone successfully made a Serial2USB converter with a Uno with its shared pins 0 & 1?
I will try the SoftwareSerial library which should allow me to use pins (other than 0 & 1)  because I am concerned about communication issues if pin 0 & 1 are shared for both my serial device and the USB to the PC unless I can see some example code that works...
I appreciate the help !
pylon
Quote
What do you want to do? If you want your UNO to be a USB2Serial device you can just connect it via USB to your PC and connect the TTL serial device to pins 0 and 1. VoilĂ , you have your USB2Serial. You don't need any software to be run on the UNO, it acts as a USB2Serial converter.
If you need something else than a USB2Serial converter, tell us what you want to achieve!
The SoftwareSerial class works OK for baud rates up to 9600, with some devices even up to 38400. I personally never got beyond that limit.
