Topic: Can the Uno handle two serial port functions ? (Read 12740 times) previous topic - next topic
pylon
Quote
For what it is worth, the RJ connector on the Serial device has the following
pinout as referenced by the device:
Pin1 - RS232 In
Pin2 - +12V
Pin3 - RS232 Out
Pin4 - Gnd
Don't you think this might mean that pin 1 is the receiving pin? If that's true, you have to connect T1OUT to pin 1 of this connector and R1IN to pin 3 of the connector. I would try to measure the pins before connecting to avoid producing a short circuit.
irethedo
Quote
Quote
Pin1 - RS232 In
Pin2 - +12V
Pin3 - RS232 Out
Pin4 - Gnd
It is connected correctly as I don't get the serial from the panel T1OUT to pin 1 of this connector and R1IN to pin 3 of the connector ... I tried it just to make sure.
On another note, I was successful in reading and writing to the control panel with a USB2Serial converter which I built an interface to the RJ4 connector...
Must be something in the way the serial port & USB are shared on the Arduino that keep me from reading and writing to the control panel...
thanks for your help
pylon
Quote
If you want the Arduino to be just a USB2Serial adapter, you can just ignore the Arduino's core processor (the ATmega328p) and use the ATmega16U2 for exactly this purpose. You just have to make sure you swap the RX/TX lines because the pin marked RX on the Arduino is the reading pin of the main processor and therefore the writing pin of the ATmega16U2. And you must ensure the sketch loading on the Arduino don't get active in that communication (p.e. by loading the blink example sketch).
poulami
can arduino uno handle two com port?
