Topic: Duda con ethernet shield y millis() (Read 840 times) previous topic - next topic
juanvivo
Apr 08, 2013, 10:53 am Last Edit: Apr 08, 2013, 11:12 am by juanvivo Reason: 1
Hola a todos.
Tengo conectado a un duemilanove un ethernet shield y un lcd de 16x2.
Con uno de los codigos de ejemplo algo modificado y simplificado, leo los paquetes UDP y los muestro en el monitor serie. A la vez en el lcd quisiera que apareciera "llegan datos" o "no llegan datos", segun haya o no paquetes disponibles. El caso es que siempre aparece no llegan datos, por que entiendo que entre paquete y paquete haya un espacio vacio y prevalece. Por eso se me ocurre que deberia añadir al condicional "si no llegan datos durante x segundos...". Como haria eso con millis?
El codigo:
Code: [Select]
 UDPSendReceive.pde:
This sketch receives UDP message strings, prints them to the serial port
and sends an "acknowledge" string back to the sender
A Processing sketch is included at the end of file that can be used to send
and received messages for testing with a computer.
created 21 Aug 2010
by Michael Margolis
This code is in the public domain.
#include <SPI.h>         // needed for Arduino versions later than 0018
#include <Ethernet.h>
#include <EthernetUdp.h>         // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 177);
unsigned int localPort = 9500;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
char  ReplyBuffer[] = "acknowledged";       // a string to send back
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
 // start the Ethernet and UDP:
 Ethernet.begin(mac,ip);
 Udp.begin(localPort);
 lcd.begin(16, 2);
 // if there's data available, read a packet
 int packetSize = Udp.parsePacket();
 if(packetSize)
  // read the packet into packetBufffer
   Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);
   Serial.println("Contents:");
   Serial.println(packetBuffer);
   lcd.setCursor(0, 0);
   lcd.print("Llegan datos");
 }else{
   lcd.print("No llegan datos");
 delay(10);
juanvivo
He probado esto, pero sin exito...
Code: [Select]
  if(packetSize)
    contador = 0;
  }else{
      long p;
      if(contador = 0){
        p = millis();
        contador = contador + 1;
      if(contador>=1){
        if ((millis()-p)>3000){
  delay(10);
juanvivo
Van por ahi los tiros o estoy muy desencaminado? sabeis de algun ejemplo parecido?
Sergegsx
puedes tener una variable que almacene la ultima vez que llegaron datos. luego si ese valor es mayor a un intervalo que tu quieras muestras un mensaje u otro
algo asi...
Code: [Select]
unsigned long previousmillis_datos;
si llegan datos
previousmillis_datos = millis();
si (millis() - previousmillis_datos > 10000)           // 10 segundos
imprime han llegado datos
imprime no han llegado datos}
juanvivo
No habia visto la respuesta, voy a probar!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
