Loading...
Pages: [1]   Go Down
Author Topic: Any documentation on this shield?  (Read 725 times)
Chicago
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Picked up this shield from Mouser. Looks like an official arduino proto shield, but I couldn't find any info on it on this site.
Is this an official board or a clone? Judging by the silk screen I can see where some of the bag of parts that it came with goes, but looks like there's lots of extras. I was hoping there was some documentation somewhere to look at.
« Last Edit: January 11, 2011, 09:34:17 am by johndimo » Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Hmm, never seen that one before...
Logged
Ohio
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
can you post a URL for the shield. Or product ID?
Logged
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
Hmmm  Looks nice and not too hard to figure out.  I like it.
I would venture to say that it is one of the few proto boards available that carries UP to the shield what it covers up...
1) ICSP copied  up to shield (if you want it)
2) Reset Switch is there
3) Status leds are there
These all serve the same function as they do on the main board and would therefor be wired in parallel.
All the other stuff is just proto area.  I might have to get one of these...
hehe...  I love Mouser... I just ordered.
« Last Edit: January 11, 2011, 02:25:23 pm by pwillard » Logged
Chicago
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
Quote
Sure.
Carries Part number A000025
http://www.mouser.com/ProductDetail/Arduino/A000025/?qs=sGAEpiMZZMs0PWRNvpRp0AmfYVBxQcXp
Comes with the board, 40 pin header strip, 6 pin ISP header, 3 5mm LEDs (Red, Green, Yellow), 2 switches, and 15 resistors (5 ea. 10k, 1k, 220).
Brings up the ISP header and reset from below only from what I see. Gives 2 dedicated spots for LEDs for use as you please, +5vdc and GND rails, a 14 pin SMD breakout section and a 20 pin DIP breakout section in addition to general prototyping area.
I like it.
Mouser also sells a standalone proto shield (A000024) with no components.
http://www.mouser.com/ProductDetail/Arduino/A000024/?qs=sGAEpiMZZMs0PWRNvpRp0P1MoxM%252bXyB9
Judging by the pictures on Mouser, I got a completely different board than what they have pictured. Mine has the DIP section and an Arduino logo on it.
« Last Edit: January 11, 2011, 03:29:57 pm by johndimo » Logged
Indonesia
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
you can used pin headers for ICSP pins.
Quote
reset pin from small reset.
Quote
led from common ordinary led.
The protoboard look's nice...but when deal with FT232 smd became very hard to solder.
Jeckson
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
A "protoshield" like this doesn't usually have much actual circuitry.  It is designed to hold various standard components (connectors to the board below, reset switch, LEDs with current limiting resistors, etc), and allows you to connect them (plus additional components) however you want to achieve relatively simple but "professional looking" custom shields - what you might want to do if your circuit is so simple and so cheap that it really doesn't make any sense to design a PCB, but you want more physical "solidness" than you'd get with free space wiring or a protoboard.
You can look at one of these similar protoshields to get an idea how they are put together and used:
http://www.ladyada.net/make/pshield/
http://www.arduino.cc/playground/Tutorials/Protoshield
Logged
Cumming, Ga
Offline Offline
Edison Member
View Profile
WWW
I just got mine.  Well made.  Nice that they added some parts.
I'm very pleased.
Logged
Pages: [1]   Go Up
Print
Jump to:
