Topic: Platinum resistance sensor RTD (Read 4669 times) previous topic - next topic
Boardburner2
I am considering building a platinum resistance thermometer, the probes are very expensive though.
There are some very affordable ones but they come with short tails.
Any idea how to connect to these ?
Solder would melt at service temp.
dc42
What temperature range do you want to measure? A thermocouple may be an easier option.
Boardburner2
I have another thread discussing the thermocouple.
Range is as high as I can get, it's to get more confidence in the thermocouple readings.
dc42
Boardburner2
Thanks looks just the job.
Only twice the price of the platinum sensor ????
CrossRoads
MAX31865
http://www.maximintegrated.com/datasheet/index.mvp/id/7900/t/al
SPI back to the Arduino.
http://www.digikey.com/product-detail/en/MAX31865ATP%2B/MAX31865ATP%2B-ND/3681476
dc42
I just found some cheaper solutions by searching for "ceramic terminal block" on eBay.
Boardburner2
Many thanks , looks just the job, anyone know of a uk supplier for that chip please?
Docedison
Remember the HP Test equipment that used the ceramic terminal blocks?... I still have an HP 5" 5 MHz scope with those things in it...
Doc
--> WA7EMS <--
Boardburner2
Thanks for the replies, I have now found a supplier, however the package is very small and will probably be beyond the resolution of my printer and soldering ability.
Can anyone suggest a solution?
I know that adapter boards are sometimes to be found to other footprints, however please do not suggest eBay unless it someone you have personally dealt with and are happy with.
Fwiw I had a board for an Amtel project last year which i suspect had been immersion tinned,it was totally unsolderable,probably  because it had been stored too long, it cost me dear in lost components.
CrossRoads
Look at dipmicro.com, they have a bunch of SMD adapters. I have a little stockpile of different sizes waiting to go into some project.
Boardburner2
Thanks,
Spot on.
1/3 price of RS, and I noticed not tinned which is exactly what I want.
CrossRoads
RS? Radio Shack, or something else?
Boardburner2
RS components, Used to be Radio Spares I think.
V expensive.
Equivalent to Radio Shack over here would be Maplins.
dc42
V expensive.
Actually, prices at RS Components are generally not that bad. SMD adapters are an exception, because the only ones that RS (and Farnell) stock are the ridiculously expensive Roth Electronik ones. I get my SMD adapters from SparkFun distributors, Futurelec etc.
