Library: pwm01.hDescription: A clean alternate approach for setting up unique PWM frequencies from within a sketch, for any or all PWM pins. The trick is to utilize the two PWM clocks (CLKA & CLKB) provided by the SAM3X8E chip.I wrote and enclosed a library (pwm01.h). It includes 4 user functions to: 1) setup PWM resolution, 2) setup PWM pin, frequency & pick clock, 3) write duty cycle, and 4) stop PWM. See example code for usage:Code: [Select]#include "C:\Programs\arduino-1.5.1r2\hardware\arduino\sam\libraries\Pwm01\pwm01.h"void setup() { uint32_t pwm_duty = 32767; uint32_t pwm_freq1 = 2; uint32_t pwm_freq2 = 5000; // Set PWM Resolution pwm_set_resolution(16); // Setup PWM Once (Up to two unique frequencies allowed //----------------------------------------------------- pwm_setup( 6, pwm_freq1, 1); // Pin 6 freq set to "pwm_freq1" on clock A pwm_setup( 7, pwm_freq2, 2); // Pin 7 freq set to "pwm_freq2" on clock B pwm_setup( 8, pwm_freq2, 2); // Pin 8 freq set to "pwm_freq2" on clock B pwm_setup( 9, pwm_freq2, 2); // Pin 9 freq set to "pwm_freq2" on clock B // Write PWM Duty Cycle Anytime After PWM Setup //----------------------------------------------------- pwm_write_duty( 6, pwm_duty ); // 50% duty cycle on Pin 6 pwm_write_duty( 7, pwm_duty ); // 50% duty cycle on Pin 7 pwm_write_duty( 8, pwm_duty ); // 50% duty cycle on Pin 8 pwm_write_duty( 9, pwm_duty ); // 50% duty cycle on Pin 9 delay(30000); // 30sec Delay; PWM signal will still stream // Force PWM Stop On All Pins //----------------------------- pwm_stop( 6 ); pwm_stop( 7 ); pwm_stop( 8 ); pwm_stop( 9 );}void loop() { }The pwm01.h library and example code were tested in IDE 1.5.1r2. Additional notes on this library:- Applies to Arduino-Due board, PWM pins 6, 7, 8 & 9.- Libary Does not operate on the TIO pins.- Unique frequencies set via PWM Clock-A ("CLKA") and Clock-B ("CLKB") Therefore, up to two unique frequencies allowed.- Set max duty cycle counts (pwm_max_duty_Ncount) equal to 255 per Arduino approach. This value is best SUITED for low frequency applications (2hz to 40,000hz) such as PWM motor drivers, 38khz infrared transmitters, etc.- Future library versions will address high frequency applications.- Arduino's "wiring_analog.c" function was very helpful in this effort.
