Topic: Infrared wavelength (Read 5696 times) previous topic - next topic
panosip
Apr 10, 2013, 12:39 am Last Edit: Apr 16, 2013, 12:05 am by panosip Reason: 1
Hello.
In order to detect both a 940nm and 850nm wavelength signals, I need to use an 940nm and 850nm receivers?
I need, the 940nm wavelength, to be detected only by one receiver (with no scattering - ir beam) and the 850nm only by the other one. Is this possible?
p.s: I'm thinking of buying an Wrobot Digital 38KHz receiver/transmitter. Does anyone knows its wavelength?
Thanks in advance
Grumpy_Mike
Quote
No.
A 850nm sensor and a 940nm will both respond to either wavelength emitter, it is just that the sensitivity will be less.
Quote
I'm thinking of buying an Wrobot Digital 38KHz receiver/transmitter. Does anyone knows it's wavelength?
I don't know but find out what IR receiver chip it uses and look up the data sheet, it will tell you the wavelength.
panosip
Quote
Thanks for your reply.
What about with a 300nm and 940nm instead?
Grumpy_Mike
Quote
Well 300nm is up in the ultra violet region. Can you get 300nm detectors?
You would have to look at the sensitivity curve in the data sheet but in general a high energy photon will always induce current in a low energy photon detector without filtering.
adrian_h
#4
Apr 11, 2013, 02:19 am Last Edit: Apr 11, 2013, 02:26 am by adrian_h Reason: 1
Practically speaking, the farther off the wavelength is off from the tuned receiver, the less it will respond.  This is how the eye works with just being able to see only 3 colours, red, green and blue.  All three receivers have some overlap (the red receiver overlaps green, but red doesn't overlap blue that much).  However, because of the different amount they respond to any wavelength, the brain can approximate what the wavelength is and attach a colour to that received radiation.  See http://ed.ted.com/lessons/how-we-see-color-colm-kelleher.
What is it you are attempting to do?  Does it have to be outside of the visible spectrum?  Maybe you can stay within the same wavelength and use something like ALOHA protocol http://en.wikipedia.org/wiki/ALOHAnet.  A close variant is used for Ethernet communication and all communication that uses a shared medium/band.
Or maybe you can try for different colour sensors?
panosip
#5
Apr 15, 2013, 11:36 pm Last Edit: Apr 16, 2013, 12:05 am by panosip Reason: 1
Hey,
I got a 38Khz 980nm IR receiver.
I want to use an IR transmitter that the receiver will not receive the transmitting IR signal or to receive the IR signal as little as possible.
Should I use an 36Khz 940nm emitter or an 38Khz 880nm instead?
Thanks in advance:)
Grumpy_Mike
You are best using a 32KHz   880nm receiver
panosip
Preferable for the minimum efficiency of the my receiver is to use an emitter with different wavelength or different frequency?
adrian_h
I wasn't aware that emitters had a pulse frequency.  I though only receivers did.  Do you know what these numbers represent?  The 'frequency' is the pulse rate (how many times it turns on and off), the 'wavelength' is what part of the electromagnetic spectrum it is using.  I put these in quotes because a wavelength is the reciprocal of a frequency and vice versa.
If you are going to be using these (transmitting/receiving) at the same time and you don't want to get into protocol complications, you want to have each (the 'wavelength' and the 'frequency') as far off each other as is possible.  This will reduce as much as possible crosstalk between the two.
AFAIK, emitters are just IR LEDs, you have to pulse them at the correct frequency.  There are libraries available for this, but you'll have to look for them yourself.
  Try here: http://lmgtfy.com/?q=arduino+ir+transmitter+library
If you have multiple receivers controlled by one chip, you may find that they may interfere with each other depending on how the library is implemented.  Depending on your usage, you may be able to get away with one transmitter and one receiver per unit using a communication protocol like I stated earlier.  If you don't require too much data going across these two channels, you might be able to get away with it by writing your own library.
Grumpy_Mike
There is no general answer, it depends on the sensitivity of the components at the wrong setting. You will only know that from studying the data sheet of the specific devices you want to use.
