Topic: How do you make a parallel port to usb with arduino uno? (Read 2146 times) previous topic - next topic
NeoRecasata
How do you make a parallel port to usb port with arduino uno
Erdin
Could you be explain what you had in mind ?
I think it is not possible.
A USB Host Shield could be added to the Arduino, and the Arduino could detect the signals from the parallel port. But that would not result into something useful. Perhaps a mouse could be controlled, and perhaps it is possible to write a program on the PC that uses the parallel port to detect the mouse movements.
Or do you want to connect a PC to the Arduino via USB and the Arduino creates a parallel port for example for a printer. The Arduino would have to emulate an existing USB-to-serial adapter. I don't know if that is possible.
brunoaduarte
#2
Sep 20, 2013, 08:01 am Last Edit: Sep 20, 2013, 08:08 am by brunoaduarte Reason: 1
When we connect the Arduino to the PC thru USB, it creates a virtual serial port (COM1) on the computer.
I guess what he wants, is that instead of a virtual serial port, the Arduino creates a virtual parallel port (LPT1), so it can act like a USB-PARALLEL converter.
I also have this doubt. Is it possible ?
Then we connect the DB25 connector to the input pins of the Arduino making it a complete USB-PARALLEL converter.
