Topic: 16x16 LED Matrix (Read 572 times) previous topic - next topic
smarcus3
I purchased (hasn't arrived) a 16 x 16 matrix from http://www.emartee.com/Modules/bbs/frame.php?frameon=yes&referer=http%3A//www.emartee.com/Modules/bbs/viewthread.php%3Ftid%3D711%26extra%3Dpage%253D1 and I want to have it display an array which will later be programmed, but right now is static. However, I am not sure if the following code will work. Can someone proof read it.
Thanks
Code: [Select]
    int myArray[16*16] = {1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0,
              1,0,1,0,1,0,1,0,1,0,1,0,1,0,1,0}; //16x16 array;
    int A_port = 4;
    int B_port = 5;
    int C_port = 6;
    int D_port = 7;
    int OOE=2;
    int RCK=10;
    int SCKPin=9; //SCK is already defined as 13.
    int SER=8;
    int VCC=11;
    int GND=3;
   pinMode(2,OUTPUT);
   pinMode(3,OUTPUT);
   pinMode(4,OUTPUT);
   pinMode(5,OUTPUT);
   pinMode(6,OUTPUT);
   pinMode(7,OUTPUT);
   pinMode(8,OUTPUT);
   pinMode(9,OUTPUT);
   pinMode(10,OUTPUT);
   pinMode(11,OUTPUT);
   digitalWrite(OOE,HIGH);
   digitalWrite(VCC,HIGH);
   digitalWrite(GND,LOW);
   digitalWrite(SCKPin,LOW);
       for(int disrow=0;disrow<16;disrow++)            //scanning the row
         digitalWrite(RCK,LOW);
         //loadoneline();                              //load the data of a row
         //sendoneline();                              //send the data of a row
         //sendPin(disrow);
         //SelectRow
         lightArray(disrow);
         digitalWrite(OOE,LOW);                     // enable the row scanning
         digitalWrite(RCK,HIGH);                    //light a row
         delay(1);
void lightArray(int row)
  //Light the row
  Serial.print("Row: ");
  Serial.print(row);
  Serial.print(" ");
  switch (row){
case 0:
digitalWrite(A_port , 0); digitalWrite(B_port , 0); digitalWrite(C_port,  0); digitalWrite(D_port , 0);
case 1:
digitalWrite(A_port , 1); digitalWrite(B_port , 0); digitalWrite(C_port,  0); digitalWrite(D_port , 0);
case 2:
digitalWrite(A_port , 0); digitalWrite(B_port , 1); digitalWrite(C_port,  0); digitalWrite(D_port , 0);
case 3:
digitalWrite(A_port , 1); digitalWrite(B_port , 1); digitalWrite(C_port,  0); digitalWrite(D_port , 0);
case 4:
digitalWrite(A_port , 0); digitalWrite(B_port , 0); digitalWrite(C_port,  1); digitalWrite(D_port , 0);
case 5:
digitalWrite(A_port , 1); digitalWrite(B_port , 0); digitalWrite(C_port,  1); digitalWrite(D_port , 0);
case 6:
digitalWrite(A_port , 0); digitalWrite(B_port , 1); digitalWrite(C_port,  1); digitalWrite(D_port , 0);
case 7:
digitalWrite(A_port , 1); digitalWrite(B_port , 1); digitalWrite(C_port,  1); digitalWrite(D_port , 0);
case 8:
digitalWrite(A_port , 0); digitalWrite(B_port , 0); digitalWrite(C_port,  0); digitalWrite(D_port , 1);
case 9:
digitalWrite(A_port , 1); digitalWrite(B_port , 0); digitalWrite(C_port,  0); digitalWrite(D_port , 1);
case 10:
digitalWrite(A_port , 0); digitalWrite(B_port , 1); digitalWrite(C_port,  0); digitalWrite(D_port , 1);
case 11:
digitalWrite(A_port , 1); digitalWrite(B_port , 1); digitalWrite(C_port,  0); digitalWrite(D_port , 1);
case 12:
digitalWrite(A_port , 0); digitalWrite(B_port , 0); digitalWrite(C_port,  1); digitalWrite(D_port , 1);
case 13:
digitalWrite(A_port , 1); digitalWrite(B_port , 0); digitalWrite(C_port,  1); digitalWrite(D_port , 1);
case 14:
digitalWrite(A_port , 0); digitalWrite(B_port , 1); digitalWrite(C_port,  1); digitalWrite(D_port , 1);
case 15:
digitalWrite(A_port , 1); digitalWrite(B_port , 1); digitalWrite(C_port,  1); digitalWrite(D_port , 1);
  //Light the columns
  for(int i = 0; i<numShifters;i++)
  digitalWrite(RCLK_Pin,LOW);
  for (int n=0;n<8*numShifters;n++)
      digitalWrite(SRCLK_Pin,LOW);
      if(myArray[row*n] == 1)
        digitalWrite(SER_Pin,LOW);
        Serial.print("H ");
        digitalWrite(SER,HIGH);
        Serial.print("L ");
      //j=j>>1; //bitshift
      digitalWrite(SRCLK_Pin,HIGH);
                //delay(1);
   digitalWrite(RCLK_Pin,HIGH);
