Topic: Function fails with passed in variable, but works if set manually. (Read 3746 times) previous topic - next topic
westfw
Yep.  I came up with the same fix as Pyro65, once I looked at it more carefully.
You didn't have ANY special code to read the pointers from flash...
Beats me why it worked with constants, though.  I guess the compiler did most of the pointer arithmetic at compile time, so the step where it fetched inappropriate pointers from RAM was skipped.
allenhuffman
I really believe it's a compiler issue.
Nope,
Because your flasharray is an array of progmem pointers, not data. You must use pgm_read_word to retrieve the pointer.
Code: [Select]
Serial.println((__FlashStringHelper*)flashArray[i]);
This is reading the i'th value in sram, you placed the data in PROGMEM. I can see that it works on occasion for you ( and my test ), but it is still wrong.
Yes, agreed, and understood. That's what I pointed out I do in my production code (see my post from April 10, 2013).
My issue was not with that, at all,, but with the inconsistency I see with things being done behind the scenes with the compiler and preprocessor and such. I really expect I am doing more intense stuff than probably 99% of most Ardunio uses ever deal with :)  It's fun.
The challenge I faced was making code that could generate to use RAM or FLASH by altering a #define, to make it easy for end-users that do not get involved with how the tools work.
Embedded Software Engineer
UNO | Leonardo | Due | Teensy | Raspberry Pi | BASIC Stamp | OS-9 RTOS
http://www.subethasoftware.com - Established in 1990.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
