Topic: Led Matrix 24x10 (Read 891 times) previous topic - next topic
samjack
Hello,
I want to make a led matrix of 10 lines and 24 columns.
But i have a question about powering the leds.
I created a 5x5 matrix, but when 1 line of 5leds is on, the leds are dimmed
The lines are powered with a 74hc595 and the columns with another 74hc595 with on each output pin a resistor and NPN for the ground.
I don't want this problem in my 10x24 matrix.
what must i be used for powering up the matrix?
each led must have the full brightness (20mA)
i want to switch 480mA, but the 74HC595 connat and tpic6B595 is only sink.
who can help me?
my local parts shop say to use a 74LS595, but see no difference
What about a 4017 decade counter for sinking?
CrossRoads
74HC595 controlling PNP transistors to source current into anodes, 74HC595 controlling ULN2803 to sink current from cathode columns.
200mA to sink per column.
Grumpy_Mike
Depending on the way you wire it up will depend on the software you need to multiplex it.
http://www.thebox.myzen.co.uk/Workshop/LED_Matrix.html
