Topic: Bug in SoftwareSerial and inverse logic (Read 4623 times) previous topic - next topic
jenscski
When using the SoftwareSerial and inverse logic, there is a bug in the setTX method, the method does not take into account the inverse logic flag when setting default output on the tx pin.
The second line in setTX should be
Code: [Select]
digitalWrite(tx, _inverse_logic ? LOW : HIGH);
Coding Badly
Do you have a test case / a device that uses inverted logic?
jenscski
Yes, I have two of these http://seetron.com/glo416.html, they use inverse logic.
When using one of them I had no trouble, but when using two of them together, I started getting weird data on the second screen I was using. So after a time of debugging and testing I found out that if the time from the instantiation of the SoftwareSerial and the first write was to long, the data was wrong on the display. The error was that the setTX is actually starting a start bit when using inverse logic, but not the rest of the trasmission.
When using two, both of them was instantiated at the same place, but before the first write to the second screen was done, the first screen was set up, and that took a little time.
So by doing the change i suggested, the setTX does not start a start bit when the SoftwareSerial is initilized.
Coding Badly
Excellent.  You have identified a bug, you have a good test case, and you have a simple fix.
The next step is to open an issue.  Please go here... https://github.com/arduino/Arduino/issues/new ...and create a new issue report for this bug.  I suggest keeping the report brief and provide a reference to this thread.
jenscski
Reported bug as https://github.com/arduino/Arduino/issues/1361
Coding Badly
Thank you.
By creating a "pull request" you greatly increase the chances of your bug fix getting into the official release.  Are you interested in doing that?
jenscski
I think I managed to do it...
https://github.com/arduino/Arduino/pull/1362
Coding Badly
Certainly looks like it to me.  Thank you.
