Topic: PCB fabrication with copper tape + matrix board (Read 2172 times) previous topic - next topic
Some of you may find this interesting: a sub-module of my "intelligent" ATX-based bench power supply.
I have managed to fabricate the current sensing daughter-board from some matrix board and adhesive copper tape, like this:
You can read more about it on my blog here:
Comments / questions welcome of course
My blog http://8266iot.blogspot.com
it looks like a real good job but how's the soldering to the copper strips? does it melt the adhesive or are you using a 15-25 watt iron?
Thanks. I use an antex xs25...the soldering is fine, I smeared a liitle of the brown jelly flux on the copper tape first with a cocktail stick to assist flow. Either the smell of burning glue was marked by solder/flux or I didnt stay long enough to melt it.
I'd post a pic of the solder, but I'm a bit hamfisted and it looks a bit scrappy, although it certainly works
