Topic: TextMate for Arduino (Read 2683 times) previous topic - next topic
aufruf
Jan 25, 2013, 10:35 am Last Edit: Jan 25, 2013, 10:38 am by aufruf Reason: 1
Hi all,
As I would like to use TextMate as my editor I am currently trying to get it working together with Arduino. I have downloaded a TextMate Bundle for Arduino from here: https://github.com/nasser/arduino.tmbundle
Unfortunately I get the following error message:
Code: [Select]
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -DF_CPU=16000000L -DARDUINO=100 -I/Users/larslamar/Documents/Arduino/Blink -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/libraries/EEPROM/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/LiquidCrystal/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SPI/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Servo/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SoftwareSerial/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Stepper/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Wire/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Ethernet/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/SD/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Wire/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/WiFi/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/libraries/Wire/utility/ -I/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/avr/include/avr -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard -mmcu=atmega328p /Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/Esplora.cpp -o /Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/Esplora.o
/Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/Esplora.cpp:54: error: 'A11' was not declared in this scope
make: *** [/Applications/Arduino.app/Contents/Resources/Java/libraries/Esplora/Esplora.o] Error 1
Any suggestions what is going wrong here?
Many thanks!
aufruf
profwebapps
Bei mir das gleiche.
Hat keiner eine Idee woran es liegen kann?
Robot-Will
Or you can try Sublime Text (http://www.sublimetext.com/2) and Stino plugin (https://github.com/Robot-Will/Stino).
