Topic: SoftwareSerial Signal FIFO (Read 975 times) previous topic - next topic
kj9k
Hello,
I am reading information from an Maxbotix LV-WR1 through a SoftwareSerial connection.
Unfortunately, the result is delayed. I guess that I only read the next Data transmitted but not the last.
Here is the part of my software where I am reading the Data.
// UltrasonicSerial
float readUltraSerial() {
  char new;
  int inchInt = 0, counter=0;
  char * inch;
  if (UltraSerial.available()) {
    for(;;) {
      neu = UltraSerial.read();
      if (neu == 'R' || isNumber(neu)) {
        if (neu == 'R') {
        //  Serial.println();
          inch = "";
          counter = 0;
          inch[counter] = new;
          counter++;
        Serial.print(counter);
        Serial.print(" - ");
        Serial.println(new);
        if (counter == 3) {
          inchInt = atoi(inch);
          Serial.print(inchInt);
          Serial.println(inchInt*2.54);
          return (inchInt*2.54);
    return 0;
I am using an Arduino Mega 2560 and I have free HardwareSerial ports but I can't read the RS232 Data from the Sensor. If you could help me with that, it would be even better.
Thank you
robtillaart
the problem is in these two lines
    for(;;) {
suppose you have one byte available in UltraSerial, it enters an endless loop that (tries to) read a char per iteration (assuming neu and new are the same;)
add a few lines to check it.
    for(;;) {
      Serial.print("<");
      Serial.print(neu, DEC);
      Serial.println(">");
Rob Tillaart
kj9k
Thank you that helped me :-)
