Topic: Arduino Due bootloader explained (Read 1 time) previous topic - next topic
sam0737
If someone wonders why the board is booted like that, and what is that baud rate 1200 hack, or would like to build their own firmware without using Arduino.
I have a little write-up of my findings, explaining how things are booted and flashed on Arduino Due/SAM3X in the playground - here: http://playground.arduino.cc/Bootloader/DueBootloaderExplained
Kuya Marc
In your little write-up, you wrote, "flash it over the ICSP header with AVRISP technique". Is that technically correct with an ARM-based mCU?
Marcos
I run Xubuntu Linux as my only computer operating system!
Windows does not run here; Only
Graynomad
No it won't work with a SAM, I think he's referring to modifying the ATMEGA16U2 code.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Maliheh
Hi
I need to modify Due(SAM3X) Bootloader, is it possible ?
