Topic: PWM problem with a code part. (Read 989 times) previous topic - next topic
PGT
Apr 11, 2013, 11:52 pm Last Edit: Apr 12, 2013, 12:06 am by PGT Reason: 1
Well i am using some mosfet shield and the pwm signals
the idea i have is that one signal over serial will controll the light behaviour of 6 pwm pins ( 3 5 6 9 10 11)
The code accepts input as from 0 to 65 to dim leds this works nice
However i also wanted to create a slow blinking led, codes input 66 to 71  (slow) input (72 to 77) faster and input 78 to 83 fastest
i 've been looking over it for some hours nows but i dont see whats wrong here, is there perhaps a limit on the arduino ??
Here below is the complete code:
int pwmport = 0;
int pwmval = 0;
//char input = 66;
int input =0;
int pwmpin[]={3,5,6,9,10,11 }; //an array is a collection of nummer in this case pwm pins of arduino
int mode[]  ={0,0,0,0,0,0};
int counter = 0;
// >> see switch mode function
Serial.begin(57600);
// input= Serial.read();
// serial.println(i)
 input = 79;  // THIS EQUALS SET PWM PIN 11 in BLINK MODE
  pwmport = input % 6;
 if ( input<66)
 { pwmval = input * 10 / 6;
   analogWrite ( pwmpin[pwmport],pwmval );
   mode[pwmport] = 0;  }
 Serial.print ("set pin ");
 Serial.print(pwmport);
 Serial.print(" in mode ");
 if ((input>65)&&(input<72)){ mode[pwmport] = 1;Serial.println(1);}
 if ((input>71)&&(input<78)) {mode[pwmport] = 2;Serial.println(2);}
 if ((input>77)&&(input<84)) {mode[pwmport] = 3;Serial.println(3);}
 ++counter;
 for (int i=0;i<6;i++)
 { Serial.print("pin ");
   Serial.print(i);
   Serial.print("  mode=");
   Serial.print(mode[i]);Serial.print(" ");
   Serial.print("value=" );
   Serial.println(abs( -255 + (counter % 510 )));
   switch  (mode[i]) // i is the pin mode[i] is the mode for that pin
   case 0:
          ;  // do nothing it is handled above
        break;
   case 1:
        analogWrite (i , abs( -255 + (counter *1 % 510 )));
        break;
   case 2:
        analogWrite(i , abs( -255 + ((counter * 2 ) % 510 )));
        break;
   case 3:
        analogWrite(i , abs( -255 + ((counter * 4 ) % 510 )));
        break;
   default:
        Serial.print("Error");
 delay(1000); // 1  second
PaulS
The code you posted is indented horridly. While there is debate over whether the { goes on the line with the statement, or on a new lines, there is NO debate that NOTHING follows the { on the same line.
Likewise, there is NO debate about the placement of the }. It goes on a line all by itself.
Spaces between clauses in for statements make them easier to read.
But, the biggest problem is that you didn't tell us what the problem is. That code, however ugly, does something. You want it to do something. You did not tell us what either of those somethings is, though.
PGT
solved
analogWrite(pwmpin , abs( -255 + ((counter * 32 ) % 510 )));
PGT
@PaulS
just wait what you program when you switch between multiple programming languages, in short its vs2010 C# style..
and since its only text it compiles the same.. when you are used to C# its ok
typo
PaulS
I do switch languages quite often. Proper placement of curly braces is the same in C++ as in C, C##, Java, and every other language that uses them.
Just because Microsoft set the bar on the floor doesn't mean you can't raise it. Not that your style comes anywhere near what VS 2010 C# does for me.
