Topic: Welcome ArduinoDroid - Arduino IDE for Android (Read 67022 times) previous topic - next topic
4ntoine
Hi, guys.
I'm happy to announce ArduinoDroid - Arduino IDE for Android.
Features:
  • open/edit arduino sketches
  • example sketches and libraries included
  • code syntax highlighting
  • compile sketches (no root required)
  • upload sketches (FTDI-based board and Arduino Uno are supported at this time only, android devices with USB-host support required)
    works offline (internet connection is not required)
On first launch ArduinoDroid downloads and extracts SDK (about 30Mb), so about 100Mb on sdcard is required.
@ Google Play:
https://play.google.com/store/apps/details?id=name.antonsmirnov.android.arduinodroid
Blog:
http://arduinodroid.blogspot.com
CrossRoads
Lets see how popular this is - you've certainly posted it in enough places!
4ntoine
You're right
CrossRoads
I have a Galazy S3, looking forward to trying it out tomorrow afternoon.
rmm200
Only thing I see that may be missing is a serial monitor.
Works great on the Nexus 7 to an Arduino Uno R3 (needs OTG USB adapter) - but I sure would like to see debugging messages.
Or can I do that with ArduinoCommander?
md10bldr
4ntoine -
I'd really like to give this app a try on my Kindle Fire HD. Although the OS is Android based, Google (and likely Amazon) doesn't allow the kindle fire to download Apps from  Google play. Any chance you could post the .apk file elsewhere in addition to Google play?
Thanks!
Paul G.
4ntoine
I'm going to add integration code fpr 3rd-party apps so you will be able to use any existing serial monitor for this.
4ntoine
4ntoine -
Thanks!
Paul G.
I don't have such plans as there are more important tasks: autocomplete and another boards support. Probably this will be done after all and Play-independent version will containt PayPal integration instead of Google Play.
p00ky
#8
Oct 15, 2013, 03:19 pm Last Edit: Oct 15, 2013, 08:53 pm by p00ky Reason: 1
I recently downloaded Arduinodroid on my generic Android tablet. The idea of being able to write and upload sketches while on the move is very appealing. Sadly I've killed all my Original Arduinos & only have ones that i have built. All of these are normally programmed using a Silicon labs CP210X i have lying around.  The tablet has a full USB port which so far has worked with all other devices (gamepads, memory sticks, etc). I ran "USB Host Diagnostics 1.3" & that gave the port a general thumbs up. The tablet has not been rooted.
When i try and upload a sketch it  says "Unable to find endpoints".
Is the Cp210 supported? Is it a Driver problem?bAm i barking up the wrong tree?
Managed to get hold of the dmesg.log file from android just after plugging the device in.
usb 2-1: new full speed USB device number 2 using usb20_host <6>[ 476.820001] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60 <6>[ 476.820065] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 <6>[ 476.820112] usb 2-1: Product: CP2102 USB to UART Bridge Controller <6>[ 476.820152] usb 2-1: Manufacturer: Silicon Labs <6>[ 476.820185] usb 2-1: SerialNumber: 0001 <4>[ 519.054606]
it says a bit more but the copy function would not grab it, but it seems to onpw what the device is at least.
Thanks in advance :)
ReneHitz
Hi, is it possible to use the arduino robot with this tool? Can i copy the libraries from the PC?
boi_goog
I. Like this ide but it has a lot of bugs, I could not save sketch, it can already detect the usb port but avrdude is always out of sync, it hungs and exit if the "code completed" , "softwre settings" are selected from its pulldown menu. It really needs so much improvement. I also experience the same with code commander, it always says board is not suported.
lukeparker
HI Guys,
I am having trouble uploading to my uno rev 3 it keeps telling me that there was a problem uploading I am using the Asus TF201 transformer prime with the keyboard where am I going wrong?
Kind Regards
Luke
johnnybra
Hi guys,
I have Moto G 2014 and Arduino Leonardo. In the Arduinodroid when uploading there is an error: closing port
Error: Processe returned not zero result code:11
Has anyone any idea?
tandukion
I really hope there will be an update which cover:
- arduino Yun board
- serial monitor
- or maybe upload and serial monitor over IP (using bonjour like in Arduino IDE, but I don't know whether it is possible or not)
Because the idea of using arduino in android is the best match with the IoT, and Yun is the best partner I think.
Keep the good work!
Thanks before!
jwnz
Hi guys,
Hi. Which version of Android are you using? Is your device rooted? And does the error code have a line:
failed to init libusb: -99 ?
I'm working on resolving this issue and without rooting the device it is proving to be quite a handful. All additional information would be very helpful for it seems that this is a Lollipop specific (Android version 5.0.1 or higher) problem. -99, only confirms it is LIBUSB_ERROR_OTHER.
I ran into this using LG G3, version 5.0.1.
All the best,
Joonas Tuomi.
