Topic: Can you use two IR transistors and and IR LED to pan a turret? (Read 7874 times) previous topic - next topic
David82
Quote
What are the other environmental sources of IR light in an office environment?
Well, it's a 150 million kilometres away, but it's a biggie.
Quote
If they exist, then where is an IR LEd emitter/detector pair that use a spectrum that is not typically found?
Illuminators used for IR number plate recognition systems are necessarily heavily filtered to eliminate environmental IR.
Come one man. This is indoor only. I know the sun would totally mess it up. The things you're referring to are all outdoor issues. Let me be even more unnecessarily clear; In a gigantic, building sized box, with fluorescent lights, how far away can a slowly blinking IR led be to register a change in value on the IR receiver as it blinks on and off?
AWOL
Quote
I'm sorry, I don't understand that concept.
Quote
unnecessarily picky.
Ditto.
It's taken fifteen replies to get even a quarter decent statement of requirements.
The RadioShack "spec" quoted only spectral sensitivity.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
David82
You aren't going to know the answer to the question unless you've experimented with a similar project. Trying to speculate without the necessary experience is a waste of both of our time.
zoomkat
I agree. Better you waste your time than mine, but that being said, the farthest I can get from my tv line of sight is 33', and my IR remote still works.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
AWOL
Quote
I have.
I used some very large area detectors, optical filters and a modulated source.
Mostly analogue electronics (747 op-amps).
The answer? Around 6 metres, to within about 10 degrees, which was good enough, but the slew rate of the servos was the main limiting factor.
David82
That's actually a really good example. So with an LED that was twice as bright, I should get twice the distance.
HazardsMind
Ok let's think this through. You have two photoresistors focusing on one source, and you want the turret to line up with that source, correct. Regardless of what's on the turret, you want to make it so the turret is pointing directly at the source.
Well, being that you will be receiving readings from the photoresistors, in order to find the center of the two, you will need to compare the two readings and turn accordingly.
If that is the case, it is extremely simple to do. If that's not the case, then your not clearly explaining what you want to do.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
AWOL
Quote
Have you heard of the inverse square law?
David82
yea, that's all I'm trying to do. I want to know how far away the IR LED will be detected though. If I can't make it work at 100ft or so, then it's not worth pursuing.
zoomkat
Quote
Go big.
http://www.ebay.com/itm/Infrared-IR-LED-illuminator-Board-Plate-for-CCTV-Security-Camera-w-36-Light-/171023517936?pt=US_Surveillance_Accessories&hash=item27d1cbc8f0
David82
What I'm asking about is essentially the same thing as a sun tracker.
http://www.youtube.com/watch?v=bHFCJ7TXcM4
except it will need to follow an IR LED or small cluster of LEDs and be much faster on the response time. I know the servo can move much faster but maybe there is something else limiting the speed like the response time of the phototransistor. Do any of you with experience with this stuff think that it will be able to work with those modifications?
Robin2
Why not buy a couple of phototransistors and an LED for £1 or £2 (and a cheap digital multimeter if you don't have one) and do some experiments. If you gave that as much time as people have spent trying to explain the complexity of the problem you would have an answer by now - good or bad.
Then you could inform us.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
