Loading...
Pages: [1] 2   Go Down
Author Topic: Good perfboard supplies?  (Read 4764 times)
0
Offline Offline
Jr. Member
Uno momento
View Profile
I need a pair of 8x4 inch (or larger) bits of double-sided, copper clad (all square pads) perfboard.
I've looked in the usual places (ebay, amazon, verotl) and it seems to be hard to find or very expensive.
I'm looking for cheapness not quality.  Does anyone know a good place to get this stuff, or anything that would be a good alternative?
« Last Edit: January 13, 2011, 01:52:38 pm by wossname » Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Here's a 2x2 inch piece fairly cheap - maybe you could custom order something from him?:
http://www.effectsconnection.com/oscommerce/index.php?cPath=54&osCsid=86f7be482189630583457c59da45064b
Here's an 11 x 8.5 cm piece:
http://cgi.ebay.com/Tin-Plated-Double-Sided-PCB-Board-11-x-8-5cm-/220656284653?pt=BI_Electrical_Equipment_Tools&hash=item336023b3ed
The only problem I think for both of these boards is that neither meet your "square pad" needs (any particular reason the pads need to be square?)...
Also - what do you consider cheap for a piece of double-sided 8x4 inch perfboard with pads-per-hole? Do you need any ground/power planes or bus lines? Do you need plated-thru holes?
Logged
Somewhere in Arizona
Offline Offline
God Member
Arduino must be a drug, because I'm addicted!
View Profile
I actually think he means 1 pad per hole. Not necessarily square.
Logged
0
Offline Offline
Jr. Member
Uno momento
View Profile
Ah, my apologies.  Yes Jeremy is right, I meant "square pads" to indicate that I don't want stripboard.  I wasn't aware that circular pad types existed.  To be honest, circular ones would be fine too.
Am I right in thinking that these boards have one side insulated from the other (no "vias")?  I haven't been able to lay my hands on anything like this even in my local shops in town (Maplin sucks these days).
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
Ah - ok; I was thinking by "square pads" you wanted square-shaped pads around each hole, instead of circular shaped pads. I would imagine that the need would be for more surface area for bonding of solder or such, but that raises the price of manufacturing the board.
However, your explanation of individual pads as what you need suffices.
Quote
Some do, some don't - generally, those that have what appear like a "via" are called "plated-thru-hole" or "plated-through-hole" construction; those that don't (that just have a pad around each hole, one on each side) generally aren't noted as such; in other words, if the holes are connected, it will be noted in the description that it is of "plated-thru-hole" design; if they aren't, generally there won't be an indication.
PTH construction, by the way - while being more expensive, can be a preferred board, simply because the solder for a joint will have much more contact area and form a much stronger joint more resistant to flexing and other mechanical stress. However, your layout of parts when doing a double-sided design would have to be carefully considered to prevent problems, of course - whereas on a non-PTH board this wouldn't be an issue.
Logged
0
Offline Offline
Jr. Member
Uno momento
View Profile
To state my needs in detail...
The only reason I want perfboard is so I don't have to drill a million perfectly equidistant holes myself smiley  I'm going to push 192 pairs of turned-pin SIL pin sockets through the board.  It needs to be double sided because routing it all on one side of copper is impossible.
No ground planes or any other planes required.  No buses, no rails, no fries with that and no milkshake. smiley  Imagine the kind of double-sided coppered perfboard that cavemen would use - that's what I want.  But either it doesn't exist or my googling skills have abandoned me.
80 holes wide, 30 holes high (more or less) is what I need to fit all my SIL sockets on there.
« Last Edit: January 13, 2011, 05:39:04 pm by wossname » Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Quote
I'm sure something of the right size exists, or can be manufactured - it likely comes down to being able to find it, and whether you can afford the cost.
You still haven't noted what you consider "cheap"? Also - are you only looking for one board, or multiple (or many?)...
Logged
0
Offline Offline
Jr. Member
Uno momento
View Profile
Cheap would be $20 or less.  I *need* only 1, but 2 would be nice in case I screw up and break the first one (I'm a ham-fisted cretin).
Logged
0
Offline Offline
Sr. Member
Fzzt! pop Bang!
View Profile
The distributor list at the Vero website might be worth a look http://www.verotl.com/veroboard.
I know it is not elegant, but in the past I have used two single sided boards back to back with the traces at right angles to get a double sided board.
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
You might try contacting these guys and explaining your needs:
http://www.veroboard.com/
I don't think they are an "official" company - but they might have something that would work...?
Another option would be to get in contact with one of the sellers on ebay that seem to sell a lot of PCB designs - for instance, this guy:
http://stores.ebay.com/MeasureExplorer
I have heard (but I haven't ever purchased from) is a good seller; he might have something, or could get you what you need - it might be worth browsing his site/store - and getting in contact with him.
Logged
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
One thing to note about MeasureExplorer's boards is that they are not only "PPH" (pad-per-hole), but that they also have connecting traces in a grid pattern (or other pattern) between holes; you're supposed to remove the traces where you don't need lines (definitely not what you want). Still, an interesting prototyping PCB style...
[edit]As an amendment: MeasureExplorer sells several different prototyping PCB styles - some a double sided, some are single sided, some with adjoining traces, some without. I think all of the double sided PCBs are plated-thru-hole designs. Regardless, you'll note that these PCBs all look to be custom made - so maybe if you ask him nicely, he can either make up one (well, the design - you would have to order many to make it worthwhile) for you for a fee, or he could point you to an existing design, or maybe someone else or some other company who could help. [/edit]
« Last Edit: January 13, 2011, 06:02:29 pm by keeper63@cox.net » Logged
Silly-con Valley, Ca, U.S.
Offline Offline
Sr. Member
Lernin' to tinker
View Profile
WWW
Jameco has some decently priced boards but they are single sided. I was going to mention (as someone did above) bolting 2 back to back.
5.5" x 8" board, 3906 holes for $11.95
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_206587_-1
I searched "proto board pad per hole". Here is the link...
http://www.jameco.com/webapp/wcs/stores/servlet/StoreCatalogDrillDownView?langId=-1&storeId=10001&catalogId=10001&freeText=proto%20board%20pad%20per%20hole&search_type=jamecoall
P.S. These do in fact have square pads...
http://www.jameco.com/Jameco/Products/ProdDS/105162.pdf
« Last Edit: January 13, 2011, 06:34:10 pm by biocow » Logged
10 PRINT CHR$(7)
20 GOTO 10
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Sir, you didn't state if you required plated through holes or not with that order?
Lefty
« Last Edit: January 13, 2011, 06:40:48 pm by retrolefty » Logged
Rural Arizona
Offline Offline
Edison Member
Incorrigible tinkerer
View Profile
Pretty much all the double-sided pad-per-hole boards I can recall were glass, plated-through,  and expensive.
I came across this ebay vendor when I was shopping for deals on stripboard,  and I think they had some pad-per-hole boards,  too.  Unfortunately,  they're on vacation for the next few days,  and ebay won't run searches on them right now.  But you might want to check them later, if you're not in a rush.
I've had some unhappy experiences with non-plated-through double-sided boards.  If you really want to wire on both sides,  I suggest using wire-wrap sockets,  and spacing them above the board a mm or two,  so you can solder directly to the pin.  It's an ugly kluge, but it beats finding out after the fact that you have bad connections buried in the rat's nest.
Logged
Offline Offline
Brattain Member
View Profile
Quote
I agree, Victor boards ($$$) come to mind. Most of the inexpensive pad per hole boards, both single and double side, I've seen on e-bay do not have PTHs. I've not been real happy with the few I've tried, easy for the pads to lift off with too much soldering heat or too much mechanical stress. The pads are just glued to the base material.
Lefty
« Last Edit: January 14, 2011, 01:09:56 pm by retrolefty » Logged
Pages: [1] 2   Go Up
Print
Jump to:
