Topic: Good perfboard supplies? (Read 19682 times) previous topic - next topic
AlphaZeta
#15
Jan 14, 2011, 07:07 pm Last Edit: Jan 14, 2011, 07:08 pm by AlphaZeta Reason: 1
Someone on this forum suggested http://www.dipmirco.com and I have since been ordering from them. What attracted me most was the price :)
I have also ordered from http://mpja.com, http://allelectronics.com before.
wossname
#16
Jan 14, 2011, 09:12 pm Last Edit: Jan 14, 2011, 09:31 pm by wossname Reason: 1
Thank you everyone for your kind responses.  I have checked out all your links and I'm still having trouble.
I have refined my requirements a bit, in as much detail as I can muster...
- 8 by 4 inches
- double-sided
- pad-per-hole (any shape pads will be fine, although square is marginally preferable)
- plated-thru-hole doesn't matter
- no ground plane
I need this shipped to England, but there's no rush.
Again, I'm grateful for everyone's patience with this disorganised Brit's random requirements.
I never imagined that hardest part of electronics is actually sourcing parts!  This makes designing curcuits feel easy! :)
Regarding the "putting 2 single-sided stripboards back to back"... I think in doing so, the combined thicknesses will be too deep for my SIP socket pins to reach through to the far side of copper.  The boards I have seen are 1.6mm thick including copper.
Plus the two boards would have to have opposing strip orientation for the same aspect ratio.
It never rains...
I'm starting to think it would be worth using up a whole weekend just doing it the hard way and p2p wire wrapping all the pins on a bit of bare perf.  The horror!
RanTalbott
Quote
Or,  to reduce the "horror" level,  get some pad-per-hole,  and solder some of the pins from each socket to provide mechanical strength.
Is Vector still around,  making the "Slit-n-Wrap"?  That's a really nice tool for doing bussed WW connections.
wossname
I've managed to get a bit of a bargain on 4 bits of single sided circular padded perf for less than £6, so I'm going to have to just man up and spend a couple of days inhaling 40% lead solder and fibreglass dust.
Wicked.
Thanks everyone for the help.  Great forum and a great dev platform.  I'm glad I took up electronics as a hobby - very fulfilling.
Cheers!
Valalvax
#19
Jan 17, 2011, 10:06 pm Last Edit: Jan 17, 2011, 10:06 pm by Valalvax Reason: 1
I hope you at least invest in a 1 pound facemask...
The currency, of course, not the weight system...
