Topic: Homemade Atmega328P-AU programmer (Read 8897 times) previous topic - next topic
SouthernAtHeart
Apr 13, 2013, 09:25 pm Last Edit: Apr 13, 2013, 09:27 pm by SouthernAtHeart Reason: 1
I read where someone put the bootloader on their SMD Atmega328P by just manually pressing/holding it on pads while the bootloader loaded.  I made this little board to do this, but before I add it to my next BatchPCB order, I had 2 questions.
I designed it where I could just plug it into pins 8 thru 13 on my UNO.  Will pins 8 and 9 supply enough current to do this task?  8 will be the ground, 9 will be +5 volts.
Also, if the connection fails during the bootloading process, does that 'brick' the chip?
thanks,
ps.  All the components (caps, crystal, and a test LED-to verify success via the blink sketch) will be soldered to the board.  Only the Atmega328P-AU will be left blank, to manually hold the chip on and bootload it.
pito
I would add a decoupling cap to VCC. Why the LED is connected to the PD3?
AlxDroidDev
I find that so risky.
Not only the risk of any discharge from your body can ruin the chip, but any minimal vibration from your hand can ruin the process.
I understand that a QFP32 socket is very expensive (shouldn`t be), but are you really willing to that that risk?
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
Coding Badly
Were I in your shoes I would...
• Get rid of the capacitor on AREF.  When burning a bootloader it serves no useful purpose.
• Follow pito's advice.  Get some decoupling capacitors on those power lines.
• Drop the crystal + capacitors.  I would use a clock signal from the programmer (are you using ArduinoISP?) instead.  Less soldering.  Fewer things that can go wrong.  Easier to fix if something is wrong.
• Have holes drilled around the target's corners so I could potentially put in "pillars" to keep the target aligned.
• Include a sketch with the bootloader that blinks the LED on PD3 as confirmation that bootloading worked.
There have been various problems reported on the forum when VCC / GND pins were left unconnected.  I suggest making a valiant effort to get them all powered.
SouthernAtHeart
Thanks for the feedback.  I'll update my design a little and try it out.
hiduino
I think he means he wants to power the jig via the Uno (ArduinoISP) pins 8 and 9.  Probably not recommended.
Coding Badly
Ah, clever.
Why not?  I can't find anything in the datasheet to contradict that.  The highest number I can find for current consumption is 9mA.
hiduino
I guess that would make it very convenient since it's small and compact to just plug the board into the Uno headers with just the 6-pins.  Yes, that is clever.
Erni
An alternative:
http://www.hobbyking.com/hobbyking/store/__27195__Atmel_Atmega_Socket_Firmware_Flashing_Tool.html
I have not tried it, and it seems a litle expensive
SouthernAtHeart
Edited my layout a bit, and will see how it works.  Yes the diode is for testing purposes, so I know it's flashed before soldering it on an important board.  I first designed it to sit inside the perimeter of the UNO, but then changed it so it sets on pins 8 thru 13, on the outside, with the chip on the very outside of the little 1" square board.  I have a tiny spring clamp, about like a clothes pin, I can clamp the chip on with that, visually inspect it for squareness, and flash away.
I'll let you know how it works in about a month.
Coding Badly
Are the six through-hole pads meant to be aligned?
SouthernAtHeart
Yes. If it works, ill post more photos.
Coding Badly
Just so you know ... in the image you posted every other pad is aligned.
JChristensen
https://www.sparkfun.com/tutorials/114
Coding Badly
Clever.  I'll have to modify (after searching) the six-pin ISP header.  Thanks.
