Topic: How to wire 3-pin 3-position key switch (Read 174 times) previous topic - next topic
Gustiakas
Hello,
I have recently bought a 3-position (OFF-ON-ON) toggle switch with key for my dashboard project. As you can undersand it will be used for starting the engine in-game. The switch has 3 pins that look like this:
The upper pin is silver color, bottom right pin is gold and the bottom left pin is bronze. So, does anybody know how to wire this switch to Arduino? I can't get it to work.
The key in the button only rotates one way - to the right.
Paul__B
You kidding?
Post a link to where it is illustrated on a website.
Grumpy_Mike
Quote
No those are normally
Centre connected left
Centre connected nothing
Centre connected right.
You need two pins on the Arduino set as inputs with the inputs enabled. Then connect the centre to ground, left to one pin and right to the left.
Gadgetman9
Buy a cheap volt/ohm meter and trace them out.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
