Topic: i need help with working code (Read 4579 times) previous topic - next topic
datacurve
Apr 14, 2013, 11:13 am Last Edit: Apr 14, 2013, 11:15 am by datacurve Reason: 1
i made this to control my directv...but i could not figure out what frequency i should use so i made the arduino scan and it worked if i was close by but i think i may have burned out my led.... is there a problem with the code i wrote???
* IRremote: IRsendDemo - demonstrates sending IR codes with IRsend
* An IR LED must be connected to Arduino PWM pin 3.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
unsigned int rawCodes[] = {6054,1157,1220,1176,631,564,627,569,1223,572,1232,1162,1216,580,624,1169,629,1165,629};
#include <IRremote.h>
IRsend irsend;
 if (Serial.read() != -1) {
   for (int i = 0; i < 3; i++) {
      delay(40);
     irsend.sendRaw(rawCodes,32,70); // Scanning...
     irsend.sendRaw(rawCodes,32,71); //
     irsend.sendRaw(rawCodes,32,72); //
     irsend.sendRaw(rawCodes,32,73); //
     irsend.sendRaw(rawCodes,32,74); //
     irsend.sendRaw(rawCodes,32,75); //
     irsend.sendRaw(rawCodes,32,76); //
     irsend.sendRaw(rawCodes,32,77); //
          irsend.sendRaw(rawCodes,32,78); //
          irsend.sendRaw(rawCodes,32,79); //
          irsend.sendRaw(rawCodes,32,80); //
datacurve
i am going to buy another one here soon
robtillaart
if you press CTRL-T in teh IDE the code reformats the style to make it more readable.
better use
if (Serial.available() > 0)
   int c = Serial.read();
Can you tell more about what you trying to accomplish, it is quite unclear from the code alone ...
Rob Tillaart
datacurve
#3
Apr 14, 2013, 09:44 pm Last Edit: Apr 14, 2013, 09:50 pm by datacurve Reason: 1
my mother-in-law aggrivates me with the tv by turning the volume way too loud so i am trying to come up with a way to power off the box when she does so discretely. i need to figure out what freq. that would be best to use with dtv or have a better understanding of what the freq. part of the code does. the finished product will fit inside a sharpie
the part of the code i am having problems with is
70 is the frequency
the raw code now only shows the info of the show on.which for testing is fine
i am using the serial for another project like a visual basic tv remote
datacurve
i need a way to have more range;
adding another ir-led and maybe some code tweaks
MichaelMeissner
I imagine if you burned out your LED, you probably did not use the appropriate resistor.  I also imagine no matter how discrete you think you will be, you won't be, and that doing this may increase the hostilities between you and your mother-in-law even more.
datacurve
#6
Apr 17, 2013, 07:14 am Last Edit: Apr 17, 2013, 07:18 am by datacurve Reason: 1
lol it can't get any worse... but it did give me a victory she thought my box was broken... lmao
