Topic: ATmega328P targeted at low-power battery use: help needed with baby steps! (Read 13214 times) previous topic - next topic
tim7
Anyone got a precompiled 1MHz-friendly ATmega328P bootloader.hex file?
Here you go.  They're untested I'm afraid, but I'm using Optiboot on other boards at non-standard frequencies and baud-rates with no problems.
atmega328_1a.hex (Optiboot for 9600baud at 1MHz)
Code: [Select]
:107E0000112484B714BE81FFE6D085E08093810001
:107E100082E08093C00088E18093C10086E0809377
:107E2000C2008CE08093C4008EE0BFD0259A86E02B
:107E300023EC3FEF91E0309385002093840096BBC4
:107E4000B09BFECF1D9AA8958150A9F7EE24FF2480
:107E5000AA24A394B5E0CB2EA1E1BA2EF3E0DF2E45
:107E600098D0813461F495D0082FA5D0023829F13B
:107E7000013811F485E001C083E083D07FC08234F3
:107E800011F484E103C0853419F485E09CD076C0F8
:107E9000853579F47ED0E82EFF247BD0082F10E0C2
:107EA000102F00270E291F29000F111F84D07801E1
:107EB00065C0863521F484E086D080E0DECF84364C
:107EC00009F040C066D065D0082F63D080E0E81686
:107ED00080E7F80618F4F701D7BEE895C0E0D1E0D6
:107EE00058D089930C17E1F7F0E0EF16F0E7FF06A2
:107EF00018F0F701D7BEE8955ED007B600FCFDCFBD
:107F0000A701A0E0B1E02C9130E011968C9111977F
:107F100090E0982F8827822B932B1296FA010C0160
:107F2000A7BEE89511244E5F5F4FF1E0A038BF0770
:107F300051F7F701C7BEE89507B600FCFDCFB7BE05
:107F4000E8951CC0843761F424D023D0082F21D0B9
:107F500032D0F70185917F0114D00150D1F70EC0C6
:107F6000853739F428D08EE10CD085E90AD08FE02E
:107F700084CF813511F488E018D01DD080E101D084
:107F80006FCF982F8091C00085FFFCCF9093C600E3
:107F900008958091C00087FFFCCF8091C00084FDD0
:107FA00001C0A8958091C6000895E0E6F0E098E150
:107FB000908380830895EDDF803219F088E0F5DF4B
:107FC000FFCF84E1DECF1F93182FE3DF1150E9F7D5
:107FD000F2DF1F910895282E80E0E7DFEE27FF27CC
:027FE000099402
:027FFE0000057C
:0400000300007E007B
:00000001FF
atmega328_1b.hex (Optiboot for 4800baud at 1MHz)
Code: [Select]
:107E2000C20089E18093C4008EE0BFD0259A86E02D
:027FE000099402
:027FFE0000057C
:0400000300007E007B
:00000001FF
boards.txt entries:
Code: [Select]
atmega328_1mhz_9600baud.name=Optiboot 1MHz 9600baud
atmega328_1mhz_9600baud.upload.protocol=arduino
atmega328_1mhz_9600baud.upload.maximum_size=32256
atmega328_1mhz_9600baud.upload.speed=9600
atmega328_1mhz_9600baud.bootloader.low_fuses=0xff
atmega328_1mhz_9600baud.bootloader.high_fuses=0xde
atmega328_1mhz_9600baud.bootloader.extended_fuses=0x05
atmega328_1mhz_9600baud.bootloader.path=optiboot_v50
atmega328_1mhz_9600baud.bootloader.file=atmega328_1a.hex
atmega328_1mhz_9600baud.bootloader.unlock_bits=0x3F
atmega328_1mhz_9600baud.bootloader.lock_bits=0x2F
atmega328_1mhz_9600baud.build.mcu=atmega328p
atmega328_1mhz_9600baud.build.f_cpu=1000000L
atmega328_1mhz_9600baud.build.core=arduino
atmega328_1mhz_9600baud.build.variant=standard
atmega328_1mhz_4800baud.name=Optiboot 1MHz 4800baud
atmega328_1mhz_4800baud.upload.protocol=arduino
atmega328_1mhz_4800baud.upload.maximum_size=32256
atmega328_1mhz_4800baud.upload.speed=4800
atmega328_1mhz_4800baud.bootloader.low_fuses=0xff
atmega328_1mhz_4800baud.bootloader.high_fuses=0xde
atmega328_1mhz_4800baud.bootloader.extended_fuses=0x05
atmega328_1mhz_4800baud.bootloader.path=optiboot_v50
atmega328_1mhz_4800baud.bootloader.file=atmega328_1b.hex
atmega328_1mhz_4800baud.bootloader.unlock_bits=0x3F
atmega328_1mhz_4800baud.bootloader.lock_bits=0x2F
atmega328_1mhz_4800baud.build.mcu=atmega328p
atmega328_1mhz_4800baud.build.f_cpu=1000000L
atmega328_1mhz_4800baud.build.core=arduino
atmega328_1mhz_4800baud.build.variant=standard
DamonHD
Ooooo!  Lovely, thanks!
I'll give that a whirl in the morning when I can get at my ISP!
Rgds
Damon
PS. Down to ~20uA for my 1Hz control loop with 8MHz clock, so at 1MHz...  B^>
Docedison
Thank You tim7 for the nice job... I can use them myself for several low powered battery powered applications..
and Thank You @ DamonHD for asking the questions...
Doc
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
DamonHD
Hi Tim,
Should the extended fuse be 0x06 to allow for 1.8V BOD?
Should the low fuse be 0x42 at least to have the /8 clock prescaler selected for the 8MHz RC clock?
Rgds
Damon
DamonHD
I have just successfully used your bootloader, thank you, with fuse modifications and other tweaks for my IDE:
Code: [Select]
atmega328_1mhz_4800baud.name=Optiboot 5 for bare 328P, 1MHz internal clock, fast start, 1.8V BOD, 4800baud upload, c/o tim7 20130416
#atmega328_1mhz_4800baud.bootloader.low_fuses=0xff
atmega328_1mhz_4800baud.bootloader.low_fuses=0x42
#atmega328_1mhz_4800baud.bootloader.extended_fuses=0x05
atmega328_1mhz_4800baud.bootloader.extended_fuses=0x06
#atmega328_1mhz_4800baud.bootloader.path=optiboot_v50
atmega328_1mhz_4800baud.bootloader.path=atmega
Rgds
Damon
DamonHD
And I have the system running from 2xAA NiMH as planned, drawing about 1uA for the AVR and about 2uA average for the LED being flashed.  So, it definitely seems to work!
Many thanks again!
Rgds
Damon
tim7
Thanks for letting us know it worked.  Quite right about the fuses, I forgot they'd need alteration.  BTW Optiboot is maintained by WestfW at http://code.google.com/p/optiboot/, and he's made the code very easy to compile using the tools already included in the Arduino IDE.
DamonHD
Unfortunately I don't currently even have anything as basic as "make" on my ageing Mac, and my puny SheevaPlug doesn't really have space.
I *could*/should try and set up a build/dev environment in the corner of one of my chunky hosted servers, but it somehow feels evil using a big fat machine half around the world away to do my uC builds.  Still, that's the "cloud" I suppose!
Rgds
Damon
tim7
If you have the Arduino IDE running then you already have everything you need (I'm less sure about Macs, but I think this is true).  Just get the half-dozen-or-so files that make up the bootloader source code and put them in a directory in .../hardware/arduino/bootloaders/.
DamonHD
So, if I put the .c (etc) files in that directory, how does a hex file built against the correct preprocessor directives (such as F_CPU) happen?
Rgds
Damon
