Topic: Where to buy Solid state relays 3v (Read 2939 times) previous topic - next topic
Suriken
Apr 16, 2013, 11:10 am Last Edit: Apr 16, 2013, 11:38 am by Suriken Reason: 1
I am looking for some solid state relays for my develop. I am using an arduino fio so I think it should be swithed at 3v.
I know ssr are more expensive than mechanicals but all websites I check they are x6 or more times... If I just needed one, I just buy it but I need about 7 or 8...
I want that my develop keep working for 3 years or more and almost sure it has to change the state of the relay every 20 seconds.
My requeriments for the relays are: 220v AC, 2A. switched by Arduino fio 3vDC
Thanks!
EDIT: I just found this http://www.ebay.com/itm/1PCS-ZG3M-308B-Solid-State-Relay-8A-Output-90-480VAC-/271159416771?pt=LH_DefaultDomain_0&hash=item3f225c57c3
What do you think about it? I will use some lamps 150-200w with it... but maybe I use 400w sometimes...
Erdin
#1
Apr 16, 2013, 12:11 pm Last Edit: Apr 16, 2013, 12:13 pm by Erdin Reason: 1
That is unbelievable cheap, so it is probably very simple.
But if you load is only lamps, you can try it. And inductive load like a motor requires a good electric noise suppression.
If it doesn't get hot, it will probably keep working.
If you want to be sure, buy a few and open one to see what is inside.
Suriken
When you say "it", you mean motor or relay? My lamps are normals but some of them are ceramic lamps and they get so hot...
cjdelphi
http://www.ebay.com/itm/New-SSR-10DA-DC-3-32V-Input-10A-SSR-Single-Phase-Solid-State-Relay-Heat-Sink-E0X-/160991900332?pt=LH_DefaultDomain_0&hash=item257bdd72ac
I bought a couple of these, they're just sitting on the floor bagged up still until my thermocoupler arrives :(  but these feel very solid and well built for the price ......
Erdin
I was only talking about the SSR (Solid State Relay).
...so the SSR is probably very simple...
... you can try the SSR...
... If the SSR doesn't get hot ...
... buy a few SSRs and open one ...
I have one of those larger SSRs, a SSR-25DA. They are also very cheap, but they seem okay. They have a large noise suppression, a small lamps could glow very dim if the SSR-25DA is switched off.
Suriken
Thanks both.
Those relays seem too big for me. They are bigger than arduino fio  :smiley-yell: I think I will order a couple of simple ones I posted and check if they work fine or not. When I receive them, I will open one of them and post photos here.
fungus
Why would it be complicated?
I don't know what's inside one but I imagine it's just a few diodes and MOSFETS.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
cjdelphi
There has to be some kind of mosfet capable of handling > 240volts and maybe an Optocoupler?
I'd love to see images, unless i go outside and started bashing the relay against the concrete, I have no other tools to open one up with and find out for myself :)  so please do :) remember to take pictures :P
pwillard
Quote
Mosfets?  No, that's unlikely.
SSR's are for AC loads and though therefore have an AC component like a TRIAC (which is a bi-directional Thyristor/SCR).  It would also have an opto-coupler and some snubbing passive components along with (in the good ones) some zero-crossing based gate control.
Making your own would likely cost more than buying a ready made one... but people do it.   IE, Buy MOC3010 (or MOC3024) for opto-coupler, a ON SEMI Part # T2800DG and find some sample Triac/SSR circuits...   like...
