Topic: Arduino Due with USB Weatherboard (Read 939 times) previous topic - next topic
awest5
Apr 17, 2013, 01:27 am Last Edit: Apr 17, 2013, 02:46 am by awest5 Reason: 1
Has anyone done this project yet, using the Due with the sparkfun USB weatherboard. I have been trying to get them to work together but there is no code that is designed for the Due with the weatherboard. I must be hooking into the wrong input on the Due. Any help would be great.
Code: [Select]
String weatherSentence = "";  // string to read data from the weather board
int ready = 0;                // used to mark when we have a complete string to process
char data;                    // use to read a byte from the serial
char charArray[100];          // create a char 100 position char array por parsing the data
unsigned long humidity=0, fahrenheit=0, celcius=0, SCPfahrenheit=0, presure=0;
 Serial1.begin(9600);        // starts the second hardware serial port at 9600 to communicate with the weather board
 Serial.begin(9600);         // starts the serial at 9600
 pinMode(48, OUTPUT);        // turn ON the board LED for diagnostics
 digitalWrite(48, HIGH);
 while(Serial1.available() > 0) {  // if data vailable from the weather board
   data = Serial1.read();          // read it
   if((data != '\n')) {            // if no end of line
     weatherSentence += data;      // add it to the string
   else {  // if end of line reached, readu to parse the buffer
     ready = 1;
 if(ready == 1) {                         // parse the buffer
   if(weatherSentence.startsWith("#")) {  // verify if it is a good reading
     // Serial.println(buffer);           // uncomment just to see what we got
     weatherSentence.toCharArray(charArray, 100);  // get the characters copied into charArray of size 100
     processReading(charArray);           // parse the char array extracting the data
   weatherSentence = "";                  // clean up the string for next reading
   ready = 0;
// function that parses information received in a char array
void processReading(const char packet[]) {
 byte i;
 char* endptr;
 // start parsing
 i = 0;
 i++;
 humidity = strtod(&packet[i], &endptr);       // next field: humidity
 while(packet[i++] != ','); // next field: fahrenheit
 fahrenheit = strtod(&packet[i], &endptr);
 while(packet[i++] != ','); // next field: celcius
 celcius = strtod(&packet[i], &endptr);
 while(packet[i++] != ','); // next field: SCPfahrenheit
 SCPfahrenheit = strtod(&packet[i], &endptr);
 while(packet[i++] != ','); // next field: presure
 presure = strtod(&packet[i], &endptr);
 while(packet[i++] != ','); // next field: counter
 while(packet[i++] != '$'); // next field: checksum
 Serial.print("humidity: ");
 Serial.print(humidity, DEC);
 Serial.print(" fahrenheit: ");
 Serial.print(fahrenheit, DEC);
 Serial.print(" celcius: ");
 Serial.print(celcius, DEC);
 Serial.print(" SCPfahrenheit: ");
 Serial.print(SCPfahrenheit, DEC);
 Serial.print(" presure: ");
 Serial.println(presure, DEC);
TheKitty
what are your symptoms - hangup, no data, garbled data?  Is the board compatible with 3.3 volt logic on Due?. Are you connected to rx1 and tx1 and you have rx of board to tx of due and visa versa?
awest5
Powering the Arduino by USB connection right now. I'm sending 5V from the Arduino to the Weatherboard, and I have the RX-1 from the Weatherboard to the TX1 on Arduino and TX-0 on Weatherboard to RX1 on Arduino. No data being received to the arduino from the Weatherboard.
TheKitty
can the weatherboard communicate at 3.3 volt?  if it is using 5v signals it could fry the Due input rx
awest5
Weatherboard is suppose to be operated between 3.7-12V
awest5
There is a 3.3V regulator within the board to limit voltage
Coding Badly
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
