Topic: ultra light display? (Read 963 times) previous topic - next topic
BigusDickus
Hi, I'm looking for an ultra lite weight display for an arduino. I'm currently using a 16*2 LCD (https://www.sparkfun.com/products/9052) which consists of a large chunk of glass which pushes the weight up to over 35 grams.
Anyone know of anything lighter? I don't need anything bigger or better, 16 * 2 characters is plenty, it's just the weight that needs to change. I guess it's likely to be some form of thin film flexible OLED display or something similar, the weight needs to include any chips/controllers required to use it.
any suggestions?
Thanks
elac
Here is a 1.8" display it weighs 12.5 grams and has a micro card slot on back.
Good viewing angles, not bad in direct sun. Quite easy to use.
http://www.ebay.com/itm/1-8-Serial-128X160-SPI-TFT-LCD-Modul-Display-PCB-Adapter-SD-Socket-4-Arduino-/271032247492?pt=LH_DefaultDomain_0&hash=item3f1ac7e4c4
It's all about the skills
BigusDickus
Thanks, that looks ideal, but where did you get the figure for weight from? I can't see it anywhere n the spec. Or have you got one in front of you?
Cheers
elac
After reading your post I weighed one of them on my digital scale.
