Topic: Multiple max 485 communicatio (Read 4452 times) previous topic - next topic
AJITnayak
Present code : 1 master and 2 slave.
out put file attached as below.
page1: without second slave connected. out put from Serial monitor slave1
page2: with both slave connected and  changes in out put slave1
master:
  Serial.println("WELCOME ARDUINO UNO");
  Serial.write("UNO IS WRITING");
Slave1 and slave2
Serial.println("slave1 is running");// used in salve 1 program
Serial.println("slave 2 is running");// used in slave 2 program
String content = "";
  char character;
  while(Serial.available()) {
      character = Serial.read();
      content.concat(character);
Serial.println(content);
AMPS
AWOL
Can I suggest you stop posting PDFs that don't open?
You're wasting my bandwidth.
Just cut and paste from your terminal window into a quote box.
Why are you using "String" in your receiver?
AJITnayak
i tried to insert quote , But it didn't worked for me since  i could not able to cut it from terminal window . i wanted put image but they are 2 mb file . SO i am putting PDF file.
AMPS
