Topic: low pass filter is needed? (Read 1 time) previous topic - next topic
dany151
Hi. i want a working code for lowpass filter (butterworth)..or anyother one..just i need a working code..pls help me
tobyb121
Try this:
http://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html
dany151
#2
Apr 17, 2013, 08:44 pm Last Edit: Apr 17, 2013, 08:45 pm by dany151 Reason: 1
dear i used this site to genrate the filter ..but how to program the arduino mega 2560 to perform this filter
Summary
You specified the following parameters:
filtertype  =  Butterworth
passtype  =  Lowpass
ripple  =
order  =  1
samplerate  =  30
corner1  =  10
corner2  =
adzero  =
logmin  =
Results
Command line: /www/usr/fisher/helpers/mkfilter -Bu -Lp -o 1 -a 3.3333333333e-01 0.0000000000e+00
raw alpha1    =   0.3333333333
raw alpha2    =   0.3333333333
warped alpha1 =   0.5513288954
warped alpha2 =   0.5513288954
gain at dc    :   mag = 1.577350269e+00   phase =   0.0000000000 pi
gain at centre:   mag = 1.115355072e+00   phase =  -0.2500000000 pi
gain at hf    :   mag = 0.000000000e+00
S-plane zeros:
S-plane poles:
-3.4641016151 + j   0.0000000000
Z-plane zeros:
-1.0000000000 + j   0.0000000000
Z-plane poles:
-0.2679491924 + j   0.0000000000
Recurrence relation:
y[n] = (  1 * x[n- 1])
     + (  1 * x[n- 0])
     + ( -0.2679491924 * y[n- 1])
Ansi ``C'' Code
/www/usr/fisher/helpers/gencode: input format error (6)
Error!
Command failed (return code 256)
tobyb121
#3
Apr 17, 2013, 11:04 pm Last Edit: Apr 17, 2013, 11:19 pm by tobyb121 Reason: 1
That's annoying, for some reason it is having trouble generating the c code, I've used it before and I didn't have these problems, I'll see if I can find anything else
EDIT: You could try this: https://github.com/vinniefalco/DSPFilters but it might eat up most of your program memory on the Arduino. If you are applying a low pass filter just to smooth your data, you could try a moving average.
Grumpy_Mike
There are an infinite number of low pass filters. You need to be more specific aboute what you want. Cutt off frequency, order and Q at the very least.
And do not just demand things we are not your servants.
tobyb121
This is quite a simple and reasonably well explained example:
http://baumdevblog.blogspot.co.uk/2010/11/butterworth-lowpass-filter-coefficients.html
dany151
thank you dear tobyb121
did you read this before you post?
Summary
passtype  =  Lowpass
ripple  =
order  =  1
samplerate  =  30
corner1  =  10
corner2  =
adzero  =
logmin  =
Results
S-plane zeros:
S-plane poles:
Z-plane zeros:
Z-plane poles:
     + (  1 * x[n- 0])
Ansi ``C'' Code
Error!
