Topic: Arduino Uno - GRBL - High amp motor questions (Read 1 time) previous topic - next topic
macrosloth
I want to create a CNC plasma.
I am looking at running GRBL on an Uno and had original thought to run the GRBL shield but am concerned that it cannot run larger stepper motors.   So I started to look at commercial stepping controllers.
GRBLShield.
https://www.synthetos.com/webstore/index.php/assembled-electronics/grblshield-grbl-arduino-diy-cnc-shield.html
CW320
http://www.circuitspecialists.com/cw230.html
Could I run 3x CW230's in place of the GRBLShield?
would RESET-, CW-, CP- ground on the arduino,
CW+ hookup to Directon axis pin
CP+  hookup to the Step axis pin
Thanks.
MarkT
There shouldn't be difficulty driving an opto-islated stepper controller - I presume the GRBL shield already
has step and direction pins for each axis?
However do check the interfacing requirements - so long as the controller does need more than 25mA
or so per signal no further interface hard needed (most opto isolators are 20mA or so)
