Topic: Using ISP without loosing bootloader (Read 432 times) previous topic - next topic
bratan
Is it possible to program Atmega chip with ISP in way that doesn't remove bootloader? I'm using USBTiny ISP and arduino ide, and every time I upload sketch it removes bootloader :(
Xronos Clock - A talking arduino based alarm clock is now available. Check out xronosclock.com for pictures, source code, schematics, etc.
hiduino
#1
Mar 27, 2015, 02:02 pm Last Edit: Mar 27, 2015, 02:04 pm by hiduino
No.  You have to erase the flash before programming via ISP, which deletes the bootloader as well.
Why have a bootloader at all if you are using ISP for programming?
The bootloader is only needed for serial uploading via USB or FTDI.
bratan
I see, thanks!  I actually use both. Some boards don't have FTDI header soldered yet, so I use ISP. I guess I can just make FTDI jig with pogo pins... FTDI uploads also much faster than via ISP...
DrAzzy
Depends on the ISP you're using - when you're communicating with the ArduinoAsISP at 19200 baud, of course FTDI at 110-whatever kbaud (~5x faster), of course you'll be able or program. There are much faster ISPs, you're just not using one.
Now, if you're hand flashing them, you could combine the hex files - a script could probably do this quite easily, HEX is an easy format.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
bratan
Hey that's a great idea actually! Thanks!
