Topic: LDR SENSING RELAY CIRCUIT (Read 6496 times) previous topic - next topic
ganeshkubade
I Need help in another project : i am using LDR and arduino uno and 2 relay module when LDR detects low light it trigger the relay my problem is when slight change in LDR value the relay gets flickering like fast on/ off how to get steady on or steady off ?? the relay module pin is connected to pin 12 on arduino uno...  i am using the code below ..
pinMode(4, OUTPUT);
pinMode(12, OUTPUT);
//Serial.begin(9600);
void loop(){
digitalWrite(4, HIGH);
if(analogRead(0) < 600){
digitalWrite(12, LOW);
} else{
digitalWrite(12, HIGH);
//Serial.println(analogRead(0));
JimboZA
Maybe you could experiment with the threshold value which is 600 at the moment?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
ganeshkubade
I have checked all values that mach but new success .. i need the output as on or off not fluctuating if so the relay also fluctuates and make flickering or chirping sound ..any idea ?
seadanzig
Hi try adding a delay at the end. The analogue read statement is reading it faster than yiu can blink
ganeshkubade
Hey   !!  seadanzig     You given the perfect answer what i am looking for now my Relay project is perfectly does what i need you genius.. and i have added the delay for the ON state of relay also for 10 Secs... :) by the way i am now using following revised code .. thanks for perfect solution thanks ... bye.
------------------------------------------code from here -------------------------------------------------------------------------------------------------
//pinMode(4, OUTPUT);
void loop(){
//digitalWrite(4, HIGH);
if(analogRead(0) < 590){
delay (10000);
} else{
delay (100);
---------------------------------------------------------------code end-------------------------------------------------------------------------
Klaus_ww
Another way without blocking the arduino during delay is to program a hysteresis.
Wenn ich hier sehr knapp antworte dann wegen der elenden Tipperei auf dem Tablet.
ganeshkubade
Hi , Klaus_ww  please tell me some information about hysteresis its new concept for me thanks.
Christo
Hysteresis is where there is a dead band in your logic, for instance you could switch on at a reading of 590 and switch off at say 610 giving a dead band of +-10. Your original code could be rewritten as follows:
int reading;
int deadband = 10;
int setpoint = 600;
reading = analogRead(0);
if(reading < (setpoint - deadband)){
} else if(reading > (setpoint + deadband)){
Note: untested code...
ganeshkubade
Thanks for code I will Check it.
