Loading...
Pages: [1] 2 3   Go Down
Author Topic: etching pcb at home (any suggestions)?  (Read 5338 times)
Hyderabad , India
Offline Offline
God Member
can't help not to think arduinaizing something !
View Profile
WWW
hi,
i am thinking of etching a pcb
(of arduino http://arduino.cc/en/Main/ArduinoBoardSerialSingleSided3)
any suggestions ?
Logged
SE USA
Offline Offline
Faraday Member
@ssh0le
View Profile
wear gloves
stir frequently
heat helps like setting your etching tub in hot water, never heat directly
you can fix toner transfer issues with about 3 coats of sharpie
« Last Edit: November 22, 2010, 10:23:38 am by Osgeld » Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Quote
any suggestions ?
There are some posts already on this topic in this forum and a ton of information on the internet as a whole.
Logged
www.cmiyc.com - A guide to being an Enginerd
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Osgeld THANKS
Quote
well actually i needed any advice in making a arduino at home
( perhaps i didnt name the post well  :smiley )
any new ideas ?
Logged
Central Indiana, USA
Offline Offline
Full Member
So many projects, so little time...and money!
View Profile
You could do your own single-sided serial arduino.  See the main page here: http://arduino.cc/en/Main/ArduinoBoardSerialSingleSided3
Regarding your etching, I'd try this method: http://tanjent.com/doku.php?id=pcb_fabrication
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
that was the thing i wanted to try out and will there be any disadvantages of this when compared to the readymade board?  :-/
Quote
goodlink
Logged
Cumming, Ga
Offline Offline
Edison Member
Ultimate DIY: Arduino
View Profile
WWW
I have Build 3 Single Side boards.  I had to modify the board menu so it said SEVERINO with AVR328... but otherwise there seems to be no issues with the Single sided board.  It's fine and fun to make.
I also have been using the EXACT METHODS from that GOOD LINK on fabrication.
« Last Edit: November 22, 2010, 03:58:15 pm by pwillard » Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
i would be really glad to know how to do it  smiley
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Well, do you not know how to start?  Do you have some copper clad board?
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
smiley i just ordered some copper clad board and fe2cl3  ;D and the atmega
and pillward could you let me know how to modify the board menu or atleast give your modification  smiley-wink
Logged
Newcastle, England
Offline Offline
Sr. Member
Always learning!
View Profile
WWW
Use sunlight instead of a UV chamber. Much cheaper for just one board!
Logged
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) smiley-grin
Cumming, Ga
Offline Offline
Edison Member
View Profile
WWW
Rather than just "toss you to the wolves" and give you my file... here is HOW it's done.
http://www.bhasha.co.cc/pdf/arduino_severino_manual.pdf
And who needs UV when you can just use Toner?
« Last Edit: November 26, 2010, 05:57:24 pm by pwillard » Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Quote
is this step compulsary ? i mean what if we dont modifi i guess it is just changing the baud rate waht help does that do
P.S i am not so clear as to why should we change it  smiley-wink will it work if we dont change
Logged
Hyderabad , India
Offline Offline
God Member
View Profile
WWW
Finally i tried it Today ( Exams wouldnt let me do it then )
the toner dosent stick to the copper clad board im using pohto paper with Cannon Lbp 2900 laser printer i tried it thrice! but no Sucesss smiley-sad
Logged
Portland, OR
Offline Offline
Newbie
Electronic Engineering Student
View Profile
I was just wondering about the same process, and I found this handy instructable on a solution you can use to etch infinitely. The solution is also very cheap to make, and has less environmental impact.
http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
« Last Edit: January 15, 2011, 02:49:56 am by Eiselheimr » Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
