Topic: etching pcb at home (any suggestions)? (Read 25432 times) previous topic - next topic
Jeckson
kinds to etch...
used laminator that used press n peel..
Used UV lamp used positive spray.
J
mmcp42
#31
Jan 19, 2011, 07:16 pm Last Edit: Jan 19, 2011, 07:17 pm by mmcp42 Reason: 1
dunno if this link helps:
http://fullnet.com/~tomg/gooteepc.htm
followed by
http://www.pulsarprofx.com/pcbfx/main_site/pages/tech_support/have_a_problem/have_a_problem.html
I used Xerox and HP lasers with glossy photo paper and a hot domestic iron
(not all at once - do keep up at the back there)  ;D
there are only 10 types of people
them that understands binary
and them that doesn't
pwillard
#32
Jan 19, 2011, 10:42 pm Last Edit: Jan 19, 2011, 10:43 pm by pwillard Reason: 1
I'm sure I've mentioned this in the past.   I have basically used GOOTEE's method for years now.   It's the only way I do it... including NOT using ferric chloride.
Fenrisulfr
That's one of the online tutorials I read when I was 'investigating' the TT method. True to say it was the most influential for me  :) Here's to GOOTEE!
regards
Fenrisulfr
48X24X48X
The trick is to go for semi-glossy photo paper and avoid those expensive glossy papers. Any iron would do and use adequate design clearance in PCB design.
thegeekway
Fenrisulfr, I have the same laminator(from asda, £7).  What did the mod consist of?
Fenrisulfr
Hi there.
Inside the laminator there are 2 sealed thermostats. These need removing. They are in series BTW.
The replacement thermostat is from an old clothes iron. It was fixed to the iron by a machine screw so was easy to remove.
I then used the same screw to fix the irons thermostat to the laminator. I gut a groove in the bolt up it's length for a 1/4" so it would cut and clear it's own thread in the aluminium channel. The bolt needed cutting slightly shorter so it would hod the thermostat securely.
There is also a thermal fuse strapped to the aluminium channel. Remove and join the wires together. The wires from the original thermostats connect to where the irons wires were on it's thermostat.
Do ensure that there is no possibility of making the laminator aluminium extrusions MAINS LIVE!
The plastic case needed a hole cut in it as the thermostat is quite tall. I built a shroud round it to prevent any issues with touching mains live parts. The dial is fixed with silicon sealant.
THIS IS MESSING WITH MAINS POWER PLEASE BE CAREFUL!
A thermometer would be handy as well as the scale on the irons dial isn't exactly accurate and it is easy to get the rollers smoking!
The largest PCB I have done with it was 5 x 4 inches. My unit is getting a little tired and the gears in the AC motor gearbox start slipping if the unit starts getting to warm. But it has done a lot of boards.
regards
Fenrisulfr
Valalvax
I'd like to repeat
Quote
If you do not absolutely know exactly what you're doing, DO NOT RISK IT...
Fenrisulfr
Absolutely. If in doubt just use the clothes iron as is. It is a knack and practice will pay off.
regards
Fenris
simon.monk
Yet another PCB making tutorial. But this includes a UV LED light box.
http://dl.dropbox.com/u/3993179/pcbs.pdf
I write books about Arduino and Electronics: http://simonmonk.org
