Topic: Why parallel port needs so many ground pins? Can just use one? (Read 930 times) previous topic - next topic
lightaiyee
I am using the parallel port connector DB25. I am surprised the parallel port has so many ground pins. Why so many ground pins (pins 18 to 25)? It wastes mechanical space.
As I am using a breadboard, can I just tie one pin to ground instead of all the pins? Hate spiderwebs.
zoomkat
It is what it is. Any single ground pin should work.
Google forum search: Use Google Advanced Search and use Http://forum.arduino.cc/index in the "site or domain:" box.
majenko
It stems from the days when a parallel printer cable was a ribbon cable.  Using IDC connections (Insulation Displacement Connection) the ground signals line alternately in between the signal connections providing a measure of shielding and cross-talk protection.
As the parallel port has evolved over the years some of the ground connections have been re-appropriated to other uses, but all the remaining ground connections have remained for backwards compatability.
KeithRB
It also allowed for signal grounds, chassis grounds and possibly differential pairs.
