Topic: Problema sensore di temperatura (Read 819 times) previous topic - next topic
christiank30
Ciao,
ho fatto questo misuratore di temperatura con questo sensore LM335Z e ho collegato con Arduino Uno R3 con Arduino GSM Shield che invia dati a Cosm
https://cosm.com/feeds/8526 vedi sensor_reading.Ma il codice della temperatura del sensore mi da errati dati.Che cosa devo fare?Grazie.
Code: [Select]
* Cosm Arduino sensor GSM client example.
* This sketch demonstrates connecting an Arduino to Cosm (https://cosm.com),
* using the new Arduino library to send and receive data and the new GSM library.
* Requirements
*   * Arduino with (Telefonica-designed) GSM shield
*   * Arduino software with version >= 1.0
*   * An account at Cosm (https://cosm.com)
*   * A temperature sensor connected to pin 3
* Adapted 1 April 2013 by Dan Appelquist from a sample program
* created 8th January, 2013 using code written by Adrian McEwen with
* modifications by Sam Mulube
* Full cosm tutorial available here: https://cosm.com/docs/quickstart/arduino.html
* This code is in the public domain.
#include <Cosm.h>
#include <HttpClient.h>
#include <GSM.h>
#define API_KEY "XXXX" // your Cosm API key
#define FEED_ID XXXX // your Cosm feed ID
// PIN Number
#define PINNUMBER "" // your sim PIN number if you have one (most don't)
// APN data
#define GPRS_APN       "bluevia.movistar.es"  // replace your GPRS APN
#define GPRS_LOGIN     ""     // replace with your GPRS login
#define GPRS_PASSWORD  ""  // replace with your GPRS password
// initialize the library instance:
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// Analog pin which we're monitoring (0 and 1 are used by the Ethernet shield)
int sensorPin = A3;
unsigned long lastConnectionTime = 0;                // last time we connected to Cosm
const unsigned long connectionInterval = 500;      // delay between connecting to Cosm in milliseconds
// Initialize the Cosm library
// Define the string for our datastream ID
char sensorId[] = "sensor_reading";
CosmDatastream datastreams[] = {
  CosmDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),
// Wrap the datastream into a feed
CosmFeed feed(FEED_ID, datastreams, 1 /* number of datastreams */);
CosmClient cosmclient(client);
  Serial.println("GSM Cosm Sensor Client Example");
  Serial.println("==============================");
  // main program loop
  if (millis() - lastConnectionTime > connectionInterval) {
    // read a value from the pin
    int sensorValue = analogRead(A3);
    float voltage = sensorValue * (3.3 / 1023.0);
    float temperature = (3.24 - .48828125) * 100;
    // initialize GPRS connection
    Serial.println("Initializing network");
    // connection state
    boolean notConnected = true;
    // After starting the modem with GSM.begin()
    // attach the shield to the GPRS network with the APN, login and password
    while(notConnected)
      if((gsmAccess.begin(PINNUMBER)==GSM_READY) &
          (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY))
        notConnected = false;
        Serial.println("Not connected");
    Serial.println("Network initialized");
    // send it to Cosm
    sendData(temperature);
    // disconnect the GPRS connection
    Serial.println("Network disconnected");
    client.stop();
    // update connection time so we wait before connecting again
    lastConnectionTime = millis();
// send the supplied value to Cosm, printing some debug information as we go
void sendData(float sensorValue) {
  datastreams[0].setFloat(sensorValue);
  Serial.print("Read sensor value ");
  Serial.println(datastreams[0].getFloat());
  Serial.println("Uploading to Cosm");
  int ret = cosmclient.put(feed, API_KEY);
  Serial.print("PUT return code: ");
  Serial.println(ret);
// get the value of the datastream from Cosm, printing out the value we received
// not used for this sample but useful if you want to get data back from cosm
void getData() {
  Serial.println("Reading data from Cosm");
  float ret = cosmclient.get(feed, API_KEY);
  Serial.print("GET return code: ");
  if (ret > 0) {
    Serial.print("Datastream is: ");
    Serial.println(feed[0]);
    Serial.print("Sensor value is: ");
    Serial.println(feed[0].getFloat());
PaoloP
Dopo la lettura e il calcolo della temperatura aggiungi un Serial print per verificare il valore.
Così si può capire se è il sensore a leggere il valore errato o se è l'invio a cosm.
christiank30
Code: [Select]
    Serial.println("sensorValue");
Così va bene o ho sbagliato?
PaoloP
#3
Apr 20, 2013, 02:13 pm Last Edit: Apr 20, 2013, 02:15 pm by PaoloP Reason: 1
Sarebbe meglio aggiungere
Code: [Select]
Serial.print("Temperatura letta = ");
Serial.println(temperature);
Se vuoi approfondire il linguaggio usato da Arduino ti cosiglio di leggere questa guida --> http://www.html.it/guide/guida-c/
nella parte relativa alle variabili e alle funzioni.
christiank30
La temperatura interna mi segnala 27.90°C, come posso avere la temperatura corretta?
PaoloP
Nella formula moltiplichi per 3.3. Di solito si usa quel valore quanto si utilizza il riferimento esterno ai 3.3V.
Il sensore è collegato ai 5V o ai 3V3?
