Topic: Arduino Micro powering with USB gets hot (Read 3128 times) previous topic - next topic
stefanostereo
Hey All,
Just a curiosity: I am using an arduino micro and I have just realized that it gets very hot while powering with USB / or external Vin.
Is that normal?
Thanks in advance  :smiley-roll-sweat:
CrossRoads
What gets hot? The uC chip, or the voltage regulator?
The uC chip usually only gets hot when an IO pin has been damaged. Are all of yours working ok?
fungus
Is that normal?
It can be.
What's connected to it?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
stefanostereo
Thanks to both of you!
@crossroads: The uC is getting hot. I have tested all the pins and they are perfectly working. I just cannot understand how come that it gets very hot chip and usb port. Maybe i have too sensitive fingers :D
@fungus: nothing! just plugged as it is at the usb. I tried also to use Vin with 9V battery and it has the same problem. Maybe it is just normal..I don't know
anyway..thanks for support guys! appreciate
CrossRoads
I haven't used any 32U4 chips in anything, I don't have much else to offer.
Coding Badly
Hello,
One of these?
http://arduino.cc/en/Main/ArduinoBoardMicro
Where did you buy it?
fungus
It doesn't sound normal to me. AVR chips only use about as much as an LED when they've got nothing connected. Can you measure the current (amps) being drawn when you power it with the battery?
hiduino
With the basic blink sketch loaded to my Micro the uC is still cold to the touch.  What kind of sketch have you loaded?
