Topic: Best way to control the direction of motors (Read 2053 times) previous topic - next topic
dkl65
Hello!
I am not currently working on this project. However, if I were to make an RC car with an Arduino, what would be the simplest and smallest way to control a motor's spinning direction by reversing the polarity? The motor (300mA) needs transistors to operate. So is it possible to toggle motor on and off and change its rotation direction with only PNP and NPN transistors? Or does it require another way?
Thanks!
Grumpy_Mike
Yes it is possible. Look up the h bridge circuit
dkl65
#2
Apr 20, 2013, 03:16 am Last Edit: Apr 29, 2013, 11:24 pm by dkl65 Reason: 1
Thanks Grumpy_Mike. This is an H-Bridge example:
S1   S2   S3   S4   Result
1   0   0   1   Motor moves right
0   1   1   0   Motor moves left
0   0   0   0   Motor free runs
0   1   0   1   Motor brakes
1   0   1   0   Motor brakes
1   1   0   0   Arduino dies
0   0   1   1   Arduino dies
1   1   1   1   Arduino dies
DirtBiker
Why not consider something like a L293D?  They can handle the current you are talking about and are pretty cheap.  They were designed for just this sort of application.
http://www.aztecmcu.com/sitebuildercontent/sitebuilderfiles/l293d.pdf
JimboZA
Since your question was...
.... a 293 is a good choice. Only reason to it with transistors that I can think of, is if you had a need to learn about this from first principles. Let the 293 do the electronics for you.....
This tutorial shows wiring and Arduino code.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
MarkT
If the 300mA is the no-load rating then you'll need to find out the stall-current too - that's the one that will bite you.
dkl65
How come on the Wikipedia H-Bridge chart on my reply #2 show that if the same charge is applied on both terminals of the motor, the motor will "brake"? Isn't there no current flowing?
MarkT
When both the top or both the bottom switches are on, the motor terminals are effectively shorted together,
which acts as a electromagnetic brake.
Electromagnetic braking gets stronger as the square of the motor speed, note, and lots of current can flow
(all DC motors are also DC generators).
dkl65
Will using the electromagnetic brake risk damaging the motor, other components or the Arduino?
AWOL
dkl65
And obviously, the motor is not drawing current in electromagnetic brake mode, right?
AWOL
No, it is supplying current. That's how the Prius works.
MarkT
Shouldn't do.
Depends on the set-up - full-on braking with a large motor spinning fast and lots of (moment-of-)inertia could rip the motor
off its stand!  With a small hobby motor I don't think there will be any issues...
With electric vehicles the electromagnetic braking is under PWM control so the braking force can be controlled
to the desired level, avoiding wheel-lock or damage.  Full-on braking is equivalent to stall-conditions so that the
current (and thus torque) is limited ultimately by the motor's internal resistance.
DC motors produce torque pretty much directly proportional to current, and back EMF is directly related to rotation
speed.  When under normal load the applied average voltage is roughly the same as back EMF, only the difference
between applied voltage and back EMF is available to drive current through the windings.  Braking is simply applying
0V to the windings (thus full back-EMF is available to drive current through windings)
123Splat
65,
The conditions which you have labeled as 'shoot through', should be re-labeled to something like 'OUCH!', or 'what's that smell?'.  the bridge (s) become short circuits and smoke belloweth forth...
dkl65
:smiley-surprise: I have to test that with a multimeter measuring current in series!
Do I need protection diodes to stop the back EMF or whatever from damaging the Arduino? If so, where would the diodes go?
Braking is simply applying 0V to the windings (thus full back-EMF is available to drive current through windings)
So the motor is using its back EMF to resist motion? Is there any difference between brake 0101 and 1010 (refer to chart)?
