Topic: GSM Shield Library damaged my equipment? (Read 2344 times) previous topic - next topic
renatotavares
Not sure what happened but after using the GSM Shield Library https://code.google.com/p/gsm-shield-arduino/ and send a SMS with her, my shield no longer accepts the sending of SMS in the way I had been doing.
Usually I send an SMS like this:
Code: [Select]
//Serial Relay - Arduino will patch a
//serial link between the computer and the GPRS Shield
//at 19200 bps 8-N-1
//Computer is connected to Hardware UART
//GPRS Shield is connected to the Software UART
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
  mySerial.begin(19200);               // the GPRS baud rate
  mySerial.print("\r");
  mySerial.print("AT+CMGF=1\r");
  mySerial.print("AT+CMGS=\"+918446043032\"\r");
  mySerial.print("teste");
  mySerial.write(26);
Now this command does not work anymore. Now it is only possible to send SMS like this:
Code: [Select]
#include "SIM900.h"
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
  //Serial connection.
  Serial.println("GSM Shield testing.");
  //Start configuration of shield with baudrate.
  //For http uses is raccomanded to use 4800 or slower.
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
    //Enable this two lines if you want to send an SMS.
    if (sms.SendSMS("3471234567", "Arduino SMS"))
      Serial.println("\nSMS sent OK");
  if(started){
    //Read if there are messages on SIM card and print them.
    if(gsm.readSMS(smsbuffer, 160, n, 20))
      Serial.println(n);
      Serial.println(smsbuffer);
Anyone know the reason for this and how to solve?
My shield is this http://www.elecfreaks.com/wiki/index.php?title=EFCom_GPRS/GSM_Shield
Renato Tavares, Founder and Software Developer at Resolvendo
www.resolvendo.com
bubulindo
Any reason why the baud rate is different on both examples?
This... is a hobby.
renatotavares
baud rate is the standard in both libraries, one uses in 2400, and another 19200.
Already solved the problem. Really was related to the baud rate
www.resolvendo.com
zorzano
Anyway, the library is for the Arduino GSM/GPRS Shield, not the SIM900 based. The AT commands possibly will behave different.
phmadeira
I am having exactly the same problem, and tried different baud rate
like to come back  with the first code example,but it is not working anymore, since I have tried the second one
any help
thank you
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
