Topic: OUTPUT not ouputting 5v (Read 849 times) previous topic - next topic
mginster
I am having issues getting a full 5v out of a OUTPUT, HIGH digital pin.  When measuring with a multimeter I only get 2.8v.  After soldering to the 5v (because the LCD covers it), I properly get 5v now.  Are digital pins set as OUTPUT, HIGH not supposed to do 5v?
int HOT_WIRE = A8;
// Initial setup
  myGLCD.InitLCD();
  myGLCD.clrScr();
  //Make 8 hot for 5v
  pinMode(HOT_WIRE, OUTPUT);
  digitalWrite(HOT_WIRE, HIGH);
Erdin
Which Arduino board are you using ?
Grumpy_Mike
No they are not.
According to the data sheet a logic HIGH can be anything above 4.2V.
Of course it depends on what it is connected to. A load greater than 20mA will reduce this.
mginster
I am using a Mega 2560.
When testing the voltages, the only items hooked up were an LCD/Touch shield (not the actual LCD though).  I had the hot wire going to a breadboard and made my measurements off of that, nothing else was hooked up to the breadboard.
2.8 still seems low, but it does get the job done with my relays....
fungus
You'll only get 5V if you're not overloading the pin (ie. not trying to use it to power other devices).
If it's dropping down to 2.8V you're drawing too many amps and your pin is about to die.
James C4S
Are you trying to power the LCD with the pin?
mginster
Nope, it is an unused pin from the LCD shield.  Its just a pass through hole on the shield.
MarkT
An unloaded pin that's set HIGH should be millivolts away from the 5V supply - its being pulled high by a FET
with an on resistance of around 50 to 100 ohms.   If its reading 2.8V it suggests its either not set as an OUTPUT
(ruled out by the code snippet) or there is too heavy a load on it or the pin is burnt out.
fungus
Either something is connected to it that you don't know about or it's damaged (from a previous overload).
Try removing the shield and test it again.
